3.0 to 3.4 swap problem
I completed the swap and I have no spark and no injector pulse. This ECM came out of donor vehicle which is a 1999 4Runner Limited with transponder key. I have been assured that if you eliminate the ground that this ECM will work. I changed ignitor and still no spark or injector pulse. I have 12volts to Ignitor and injector. I have now ordered an ECM for a non-transponder key 1999 4runner. Is there anything else I could be missing. Scanner communicates with all components. Crank sensor, RPM, Cam sensor, fuel pump. it is all working but no spark or pulse.
steve miller
10-10-2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
