Radiator capacity for 1996 V6 4WD 4 Runner
Old 08-23-2004, 09:58 PM
Jolooj's Avatar
Hi folks,
A quicky, what is the radiator capacity for a 1996 4 Runner V6 4WD? What's a simple but safe way of putting in fresh coolant? Is distilled water necessary?
Thanks.
Steve
Jolooj is offline
Old 08-24-2004, 07:42 AM
ranma21's Avatar
I bought 2 gallons of undilluted red coolant form Toyota last time to do the maintenance. You will need to dilute it by using distilled water in a 50/50 ratio. Make sure you use distilled water to avoid any deposit in your radiator.
ranma21 is offline
Old 08-25-2004, 06:31 AM
Jolooj's Avatar
Radiator capacity
Hi.
Am I right in saying then that 2 gallons of coolant is to be dilutes with 2 gallons of distilled water to do the job?
Steve
Jolooj is offline
Old 08-25-2004, 07:43 AM
SLC Punk's Avatar
When I installed my TRD Thermostat, I only used 1 gallon of Toyota coolant. I mixed it 60% water 40% gly and used Redline Water Wetter and had a little bit of coolant left over.
But a straight 50/50 mix, you will only need 1 gallon.
SLC Punk is offline
Old 08-26-2004, 05:40 AM
Jolooj's Avatar
Thanks for your reply
Is there any difference between distilled water and filtered water? I work in Mongolia and am unsure if distilled water is obtainable.
Jolooj is offline
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
Jdgarrison
10-01-2015 05:22 PM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: Radiator capacity for 1996 V6 4WD 4 Runner
