Coolant level consistently low
Old 05-23-2005, 05:07 PM
fatdudesurfin's Avatar
I've installed a new water pump, radiator, cap, and all hoses all snugly onto my old 3vz engine. I believe I did an excellent job and there are absolutely no leaks in these parts whatsoever. Yet my coolant level in the reservoir is consistently low. Meaning I'll fill it up, and a few miles later, its down to the same spot.
Could this be just the fluid working itself throughout the engine? what's up with this?
Thanks for all help. If what I said was a bit vague, let me know and I'll explain it more thoroughly
fatdudesurfin is offline
Old 05-23-2005, 05:17 PM
CynicX's Avatar
check your oil...if you see coolant you'll know...
CynicX is offline
Old 05-23-2005, 05:22 PM
jimbo74's Avatar
im afraid i would have t oagree with that.... if everything is tight and you are sure there are no external leaks in the cooling system, your headgasket has probably failed internally...
jimbo74 is offline
Old 05-23-2005, 05:39 PM
KevyWevy's Avatar
it could also be air bubles in the line. turn the heat on for a while and drive around and it may help to get them out more.
KevyWevy is offline
Old 05-23-2005, 05:51 PM
this will sound pretty dumb, but how will i recognize coolant mixed in with the oil?
Old 05-23-2005, 05:53 PM
forgot to ask..
how/where is the best place to check for this? i'd like to avoid draining the oil
Old 05-23-2005, 05:54 PM
rah1420's Avatar
coolant with the oil:
It'll look like a chocolate milkshake rather than simply brownish.
rah1420 is offline
Old 05-23-2005, 06:21 PM
Nic
Nic's Avatar
Your oil may appear to be white in coloration too. I guess it depends on how much is getting in the oil.
Nic is offline
Old 05-23-2005, 06:51 PM
Blair's Avatar
Originally Posted by fatdudesurfin
forgot to ask..
Just look at your dipstick.
If it looks like a milkshake, you got some problems with your head gasket
Blair is offline
Old 05-23-2005, 06:54 PM
DH6twinotter's Avatar
Have you checked your heater hoses? One of my hoses had a slow leak and I was having to top off my overflow tank every month or so.
Also, could just be a leaking resorvoir.
Well, that's my $.02.
Have fun all.
Daniel
DH6twinotter is offline
Old 05-23-2005, 07:03 PM
jimbo74's Avatar
he said nothing leaks and he keeps on having to add coolant.....
jimbo74 is offline
Old 05-23-2005, 07:18 PM
Nic
Nic's Avatar
As suggested, it may just be your reservoir. Forget about relying on your reservoir for a little while and check it from the radiator and see if the level is getting lower in it over time. Check it when cool, of course.
I know it seems I can never keep coolant in my reservoir/overflow.
Nic is offline
Old 05-23-2005, 07:30 PM
YotaJunky's Avatar
I agree. Turn on your heater to the highest setting to ensure that you have no air trapped in the system. If this is the source of the problem, then the air pockets will work itself out. Also, do you know how much coolant you put in and how much the owner's manual says to put in?
Troy
YotaJunky is offline
Sleaker
08-26-2020 06:03 AM
raptor510
08-19-2015 02:15 PM
JefferDean
07-31-2015 10:39 AM
yourrealdad
07-29-2015 11:08 AM
Quick Reply: Coolant level consistently low
