Engine Swaps Swapping an engine in your Toy, here is where to learn how
LS Swap Baja Runner Help!!! :help:
Old 02-07-2016, 04:02 PM
MechEngineer1320's Avatar
Question LS Swap Baja Runner Help!!! :help:
Just bought a 1994 Pickup with a 3VZE and R150 trans with VF1a transfer case. Trying to figure out how to swap in my built 3rd gen LS 4.8, want to know if its possible to use a Novak adapter for LS to AX15 bellhousing then bolt the AX15 belhousing to R150 transmission?
Old 02-07-2016, 05:07 PM
If I used the AX15 Bellhousing would I need to swap to the Input Shafts?
Old 02-07-2016, 09:18 PM
Can someone atleast tell me if I'm on the right path to mating a LS to my R150?
Old 02-07-2016, 10:51 PM
donomite49's Avatar
Why don't you just use chevy trans and transfer case cause your gonna need to upgrade to stronger diffs/axles if your going to beat on it anyway.
irv
12-21-2021 12:38 PM
vickie89
3.4 Swaps
01-09-2016 06:33 PM
Ifoundyoda
12-06-2015 02:29 PM
DonHagen
12-02-2015 12:59 PM
chuckd83
11-30-2015 01:40 PM
Quick Reply: LS Swap Baja Runner Help!!! :help:
