LS Swap Baja Runner Help!!! :help:
Just bought a 1994 Pickup with a 3VZE and R150 trans with VF1a transfer case. Trying to figure out how to swap in my built 3rd gen LS 4.8, want to know if its possible to use a Novak adapter for LS to AX15 bellhousing then bolt the AX15 belhousing to R150 transmission? :help:
If I used the AX15 Bellhousing would I need to swap to the Input Shafts?
Can someone atleast tell me if I'm on the right path to mating a LS to my R150?
Why don't you just use chevy trans and transfer case cause your gonna need to upgrade to stronger diffs/axles if your going to beat on it anyway.
