Engine Swaps Swapping an engine in your Toy, here is where to learn how
engine swap
Old 05-26-2010, 09:14 AM
armassey's Avatar
engine swap
will toyota engines from sedans,fit/bolt into a truck? if so what would fit into an 86 toyota 4x4.Thanks for any info.
Old 05-26-2010, 09:23 AM
Elton's Avatar
you can make a 7M-GE out of a supra fit
Old 06-06-2010, 09:11 AM
armassey's Avatar
I bought a 22r with a 20r head.timing chain was too long,jumped time after I started it, did not damage the valves or pistons,will have to get or have shorter chain.My other problem is the tappets are at the end of the threads when adjusting the valve lash.I've read any valve train should work ? How do I solve the tappet problem, longer tappets ?I was told it has a rv cam installed. Thanks for any help !
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
Quick Reply: engine swap
