YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-30-2008, 04:38 PM   #1 (permalink)
93 22re--5VZE/Auto trans Swap
Hey guys/gals,
One of my customers asked me about a swap he wants to do in his 93 4Runner..It has a 22RE in it thats blown..Well he just picked up a 99 Runner crash victim and wants to swap the entire driveline from the 99 to his 93..So basically a 5VZE w/ atm going into a 93 Runner..I would imagine I would need to fabricate exhaust hookup which isn't my concern..My biggest question is engine and tranny mounting..Is there a conversion kit available if it is even needed....??
Driveshafts dead swaps ?
Worked for Toyota for 20 years before going out on my own and this is the first time I have ever dealt w/ this swap..
Thanks in advance for all replies...
lexushead is offline
Sponsored Links
To remove this ad, register today!
Old 06-01-2008, 06:50 PM   #2 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
http://www.offroadsolutions.com/prod...3.4l_swap_kits
They sell the wiring kits and weld in motor mounts. Drive shafts will have to be modified.
Adam F is offline
Old 08-07-2008, 06:19 PM   #3 (permalink)
R.DesJardin's Avatar
Since you have a donor, wiring from one to the other would be usable, why not swap the interior too. Otherwise buy the kit. Their kit doesn't include trans control if I remember right. But there are a couple options there too.
__________________
R.DesJardin
http://www.radesignsproducts.com
"I shift because I can!"
R.DesJardin is offline
Old 08-07-2008, 06:37 PM   #4 (permalink)
BAMF_CT2004's Avatar
read the ORS tech article. Actually go over it a few times Then browse around in the 3.4 swap section of yota. All the questions you are most likely to have will be answered in there.
__________________
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some muscle.
BAMF_CT2004 is offline
Old 08-07-2008, 06:45 PM   #5 (permalink)
Quote:
Trans control????
__________________
Old 08-09-2008, 07:54 AM   #6 (permalink)
Trans control
If you read ORS's desc. their kit it has a note (or at least used to) about only controlling the engine system.
The A340 series transmisions shift through the forward gears via solenoids in the transmission which are controlled by the ECU and ECT(trans) computers along with various sensors. If you have the donor wiring just swap it into you vehicle problem solved.
Otherwise an after market trans. contoller is required.
I put a '92 trans in my '82 and made my own shift controller, I now have figured out a way to make a much simpler one, see my website.
Take care and good luck with the swap.
__________________
R.DesJardin
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
87 4-Runner gets a 22RE to 3.4 swap - auto trans slater442w30 86-95 Trucks & 4Runners 46 02-23-2008 08:07 PM
Manual to Auto Trans Swap? Gerdo 95.5-2004 Tacomas & 96-2002 4Runners 5 04-06-2007 08:01 PM
3vze Auto Trans 22RE auto trans cweich 86-95 Trucks & 4Runners 1 01-24-2007 06:29 AM
3.4 Swap Auto Trans Options Dirtoy4x4 95.5-2004 Tacomas & 96-2002 4Runners 3 12-16-2004 01:53 PM
how to do a engine swap 22re to 3vze or the 5vze toyota_thunder Off Topic Talk 7 09-16-2003 05:00 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
