YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-28-2008, 05:42 PM   #1 (permalink)
91 yota swap?
i have a 91 yota 4x4 5 speed. i gettin ready to pull the 3.0 out and i was wondering what i should do. i the power of the 3.0 sucks. what parts could i use to get the most power out of the 3.0 or would it be better to just do an engine swap, if so what are some suggestions. open to anything without major modifications.
matt91yota is offline
Sponsored Links
To remove this ad, register today!
Old 01-28-2008, 06:41 PM   #2 (permalink)
RobD's Avatar
Swap in a 3.4 from a newer Toyota. There isn't any major fab work and the power simply blows away what you can do with a 3.0 for the same cost.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 01-28-2008, 06:56 PM   #3 (permalink)
is all the wiring the same?
Old 01-28-2008, 08:07 PM   #4 (permalink)
RobD's Avatar
Wiring is the most difficult part, but it's not that bad once you figure out the goal. There are a lot of wires that have to be traced and spliced together. It would take a couple hours with the wiring diagrams. Your other choice, albeit more expensive, is to go with www.offroadsolutions.com and look at the variety of kits available. I went as cheap as I could and it worked out fairly well. Check www.andrewzook.com for a good example of a swap.
__________________
RobD is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Anyone swap a 1JZ into a 4x4 Yota? Mudfreak General Vehicle Related Topics (Non Year Related) 2 03-21-2006 08:05 PM
Yota Fans that want Yota Toys! Check This Out! Designsbyme Off Topic Talk 4 03-04-2005 12:52 AM
lsd swap from a supra into a 2wd yota bart3lz 95.5-2004 Tacomas & 96-2002 4Runners 21 01-16-2005 07:12 PM
Yota 87 Solid Axle Swap lcopelan22 Offroad Tech 5 09-10-2003 09:42 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
