350 in a 200r4. Some questions.. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Engine Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-10-2007, 07:18 PM   #1 (permalink)
First off let me introduce myself.. My name is shawn, and im building a 95 toyota 2wd pickup. I know most of this site is based around 4x4's, However, i figured you guys might be able to help me out, since i noticed theres alot of talk about motor swaps on this site.
I fabbed up my own motor mounts, built a transmission crossmember, The motor and tranny are in place. Its a 4 bolt 350/200r4. I am going to be running a carb setup on it. The engine is stock. It's a goodwrench crate motor. GM rates it at 190/300 i believe. First question is.. Will the 2wd rear Handle the torque? And if not, i know the 4x4 rear will, But do the 2wd, and 4wd housings have interchangable axles? Reason i ask, is because The rims on my truck are almost $600 a piece, And i bought them when i was keeping the stock 22re. Didnt anticipate on swapping at the time. But after building my chassis, and realizing how ugly the stock engine/emissions setup looks in the enigne bay with all the wires and vaccuum hoses, i decided to go with a simpler setup. And i really dont want to have to change rims, and run a 6 lug in back and a 5 lug in front.
2nd question is.. Wiring wise, what am i looking at here? I know the carbed smallblock wont require alot of wiring to run, But What about my cluster, my steering column, lights, etc.. Should i just cut the stock harness up and use just the light circuits and whatnot? Or is there a kit out there i can get for the harness? I thought of going with a painless setup, But right now im just weighing my options. I want to go with the easiest/cleanest possible setup.
and 3rd.. How feasable is it to get my stock cluster to work with the carbed engine? My cluster has an electronic speedo, But my transmission has a cable drive for a mechanical speedo. i know that some of the earlier 89-95 trucks had mechanical speedos. So that solves that problem, But im just worried about the tach, and whatever other gauges are on it. Worst comes to worst, I could make a dash bezel, and run autometer gauges, But for now i just wanted to get the stock dash and cluster back in.
Any help you guys could give me would be great. Thanks.
laidout95 is offline
Old 12-18-2007, 06:04 AM   #2 (permalink)
Banned fruitloop
4runnerchevy's Avatar
swap
If your a leadfoot, no the axle will not work. I would change it anyway (the whole thing).
I would go with the stock harness, leave it all there. Buy an aftermarket tach, cause your 4 or 6 banger tach is not compatable. You can tap your motor for your temp guage, oil guage. You might just disconnect your computer (nothing is related to the guages). Otherwise wiring the swap is easy, being that the 350 is carb. As far as speedo, you can get an aftermarket speedo or maybe convert the tailshaft to the proper pulse and your electric will read it.
4runnerchevy is offline
Old 12-19-2007, 07:10 PM   #3 (permalink)
orangepeel's Avatar
i don't know if they are the same width or if you want to spend the money to have it cut down to fit but you can use a chevy rearend out of a 4x4 half ton they are the same bolt pattern and you can use your wheels
orangepeel is offline
Tags
2004r, 200r4, 2wd, 350, 4wd, 4x4, build, crossmember, engine, fj40, swap, trans, transmission, transmossion, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
FJ40 with 350 V8 - questions about engine?? GoudyMan 95.5-2004 Tacomas & 96-2002 4Runners 9 12-30-2007 03:42 PM
Chevy 350 swap header questions snakedogg Engine Swaps 5 12-06-2007 03:13 AM
Fiberglass cap in Va for $350 or trade for tires---$350 lunchindabox The Classifieds GraveYard 1 04-04-2007 06:18 AM
Chevy 350 with 350 tranny toy4whatever The Classifieds GraveYard 2 01-11-2007 02:23 PM
F-350 3.4v6 Off Topic Talk 24 11-26-2003 11:36 PM
2009 InternetBrands, Inc.
