| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Co-Founder/Administrator
Staff
Q Industries MV50 SuperFlow Hi-Volume Air Compressor
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#2 (permalink) |
I bought one about a year ago, great little unit. Fills my 265/75R16s from 15 to 32 psi in around 3 minutes each. Not as fast as a Powertank or Viair but much quicker than those cheap cigarette lighter plug ones. For the price I don't think it can be ebat.
The only bad thing I found is the fittings on the ends of the hose are a bit cheap, and can't be replaced. I broke one and ended up just buying a bigger coiled hose and putting on my own quick disconnects. |
#3 (permalink) |
Staff
Thanks Eric, I will place an order for it tomorrow morning.
I could replace the whole line with one from Powertank, that way my Powertank inflater/gauge thing I bought a few months ago would work with it too. This will be good to have, as my C02 goes fast. Many like to use it to fill back up once they see that I can go from 18 PSI to 40 PSI in about 10 seconds.
__________________
#4 (permalink) |
if you have a pep boys check them, our local store has them for $50, and local costco has the tsunami 1050 comp for $48, the only difference is a 90 degree op temp instead of 140 degree MV-50
i've had mine for a little over a year and still runs good
__________________
2003 4WD TRD Tacoma 1986 4Runner |
#5 (permalink) |
Staff
I've bought 4 of them.... gave one away as a gift, one in my car, one for my 4runner, and have one for a backup.
I picked up the last two really cheap on eBay (less than $25 shipped!) http://motors.search.ebay.com/_W0QQs...opartsQ5fsally I see some buyers have received used or inoperable units but both mine worked and looked like new. |
#6 (permalink) |
Still running my MV-1050 with my 4Air System
Been 3 years of abuse now |
#7 (permalink) |
Staff
Just placed my order.
Nice thing about them too is they do not use the cig lighter, that would not enough juice to power it anyways with the amps it draws.
__________________
#8 (permalink) |
That just reminded me of something else on mine, the battery clamps aren't the best quality. One of mine kept bending so I just replaced both with heavier ones.
#9 (permalink) |
ive had mine for a few weeks. i haven't had much time to use it, but it filled up my 32x11.5s in decent time. it's a nice compressor. i only have two complaints. first, the gauge on mine is WAY off for some reason. and secondly, the fittings they use are not standard by any means so i can't simply plug in my other accessories. but other than that it's decent. i like the portability factor.
#10 (permalink) |
Staff
Here is a solution I will probably end up doing to take care of the flimsy battery clamps.
![]() http://www.msdpowersports.com/connectors.html You can hardwire that to your battery, and the compressor wires you put on the other end. When you want to use the compressor, snap the two ends together. PS, Can someone look at the wires on the compressor and see what gauge they are? I have a feeling the battery clamps here will be to big for a quick disconnect. And then there comes a source to find smaller quick disconnects to handle the wire of the compressor.
__________________
#11 (permalink) |
Looks like 10 guage wire. I think those quick connects would be a bit big.
#12 (permalink) |
X2 for 10ga
__________________
#13 (permalink) |
Corey, I like the idea of the quick disconnect plugs too but seems like every time I get my compressor out (1050) somebody else ends up needing it on their vehicle...with their battery. Just a thought.
On my 1050 the internal crimps are super cheap. My guess is the MV50 is the same. Swap them out for some real crimps. I fried my first 1050 because the crimps failed and it shorted internally. BTW, these will not pump up bigger truck tires. The 285's on my F350 need 65psi, and the lil Q just couldn't muster it this morning for all 4. Works great for 30psi on my 'runner though.
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#14 (permalink) |
Its easy to make it take standard fittings. Remove the fitting on there and throw the whole thing out, go to anywhere you can get standard fittings and drill it out a bit and put it on..
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#15 (permalink) |
Staff
yeah, you can really mod the heck out of these little compressors. The fittings, hose, air chuck, battery clamps, power wire, air filter, and probably even the
air gauge can all be upgraded if you have the desire to. edit: i'll post some pics when i'm done with my extra one.
#16 (permalink) |
i've got one, works great. it is permanently mounted under the hood and plumbed into an air tank, pressure switch, air hose fitting, and ARB solenoid. I took the top off of the compressor, removed the factory fitting, drilled it out to normal 1\4 pipe threads and hooked it up from there. it inflates my tires super fast. i usually air down to 10psi when offroad and since i have bias swampers i only run 16 psi in the rear and 18 in the front on road. it airs up from 10 to 16 in a minute or so. definitly worth the $60 i got it for locally.
#17 (permalink) |
Staff
Mine came yesterday.
I think the total was $70 shipped to me. I get a free off road magazine too from buy my wheels from 4WD Parts, and I see in their Christmas gift guide one from Smittybuilt that is the exact same thing. I was thinking of getting a female air hose coupler end and putting it on the end of the hose so I could rig up my Powertank inflater that has the built in gauge. But I got to thinking that would not work, as you would be holding pressure on it until you pulled the trigger to inflate the tires, and when you are not releasing air by pulling the trigger, it may harm the motor. I was going to shoot a comparison video today of deflating my spare tire to 18 PSI, then air it back upto 40 PSI with both the Powertank then the MV50. However this morning I first put air into all four of the tires as they were down to around 35 PSI from it being colder out now, and I inflated them to the normal 40 PSI I carry in them, and the last tire inflated slow with the Powertank. Yup, I ran out of C02. And the local place that I get it filled at closes at noon on Saturdays, it was 11:30, to late to get down there. I will try this new thing out on the spare tire before to long to see how it works.
__________________
#18 (permalink) |
Staff
Hey Corey,
I'll show you a source for small plugs. Stop by the shop next time you fuel up. We get them from the interstate dealer or NAPA. Costco had these for $50 all summer. Gone now (I have 2)
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#19 (permalink) |
Staff
Cool, thanks Dave.
I might make it in next week to get diesel. I still have not signed back up yet with Costco, and I have been back with Boeing now over two years. Once I do sign up again with Costco, the home just fills up with crap ![]() To many good deals there.
__________________
#20 (permalink) |
I was just going to mention Costco, but looking at their site right now, they don't have them listed. Too bad, 48.00 was what they had them for. They do have a cool chrome one!
150.00 ![]() The Master Flow chrome dual piston compressor puts out 150 psi and 72 liter per minute. The handy 25-foot coil hose with gauge locking air valve makes airing up any project easy. Rubber grip handle is great for carrying, and the base tray with rubber anti-vibration feet help protect the compressor from the elements when set on the ground. Alligator power clips included, but can be modified for permanent wiring and mounting.
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#21 (permalink) |
Staff
Same specs as the one I have, and they did a nice feature, the gauge is down by the inflater end where it should be.
I am not a fan of chrome though, but you know that someone will eventually say it ![]() This would be a case where "chrome does get you home" if you had to air back up with that one.
__________________
#22 (permalink) |
I have one of these compressors hardmounted under my hood and connected with a genuine Viair 110/150 pressure switch and a 2.5 gal tank. It is a good backup to the Powertank, but it sure takes a while to air up my 37" MTR's! It took about 35-45 minutes to air my tires from 15-35psi (I was filling the tank to make it a little quicker but I am seriously considering adding another 2.5gal tank). Luckily it still will shut off still when it overheats.
__________________
DEPLOYED Again! 1994 SAS 2RZ/R151F=244:1! 1988 Toyota 4Runner SR5 |
#23 (permalink) |
Costco
I went to Costco last night and they had that same air pump with a canvas bag for 49.99
__________________
Dave S 85 4Runner Alcohol, Tobacco and Firearms should be a convenience store, not a government agency. |
#24 (permalink) |
Anybody know of a retailer here in Canada? Shipping costs doubles the price for me.
Or their website addy?
__________________
GET OUT THERE! 90 4Runner V6 Auto. 357,000k's ,31's ,Completely new brakes and Reflex shocks(Apr 07). Full chrome Warn Bush bar w/ winch. Aisin Hubs. Privacy tint, 1200W MTX Amp,2 10" Audiobahn 300W subs and 4 Sony Xplod 6x9's., Cobra 29 NW LTD Classic, OME 901's,Detroit softlocker. 99 Durango 5.9L Stock ,31's, 95L gas tank ,7seater >>(Pulls our 20' Cuddy Cabin Cruiser) Last edited by WestCoastMoose; 04-16-2008 at 08:41 PM. Reason: Web address |
#25 (permalink) |
Staff
Costco price was $39 a couple days ago.
Price drops usually happen just before they discontinue an item
__________________
| Tags |
| 2007, air, compressor, cruiser, fj, hardwire, industries, lighter, location, mf, modifications, mounting, mv50, superflow, tsunami, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| MasterFlow & SuperFlow air compressor MF-1050 & MV-50 | rocket | Offroad Tech | 66 | 06-01-2009 11:19 PM |
| Wanted: old/broken superflow or viair compressor | CenCalRunner | The Classifieds GraveYard | 3 | 02-12-2008 03:52 PM |
| A/C Compressor turned Air Compressor | Kiff | 86-95 Trucks & 4Runners | 13 | 08-15-2007 06:59 PM |
| MV50 or MF1050 air compressors | GSGALLANT | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 02-11-2007 08:58 PM |
| WTB: pop can sized air compressor (for air horn) | Brendan | The Classifieds GraveYard | 1 | 01-03-2007 08:13 PM |
