Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
problems with cv angle after sas
I have the worst possible set up. low pinion front diff and a v6 transfer case. My problem is getting my front driveshaft to reach the pinion flange at that angle. I had my i.f.s driveshaft lengthened to reach (with 8 inches of slip) but the ifs c.v. joint dosent have enough angle (it only flexes to 25degrees) i know the older trucks 86 and older had 10 degress more angle and those will flex to 35 degrees. I guess im looking for someone that is mabye running my same setup. and knows wether or not a C.V. out of a older truck will cure my problem? Thanks guys
__________________
1991 extended cab 3.0 v6 5" trail-gear sas swap 63" chevies in rear 33x12.5 cooper discoverer stt 4:88 gears with trutrac front, locked in rear warn m8000 w/arb front bumper marlin crawler rear bumper flowmaster 40 series |
| Sponsored Links |
#2 (permalink) |
Try clearancing the CV for more travel:
http://www.4x4wire.com/toyota/tech/cvmod/ Or swap it for a u-joint.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
thats what im hearing now. i had always thought cvs were better the steeper the angle. but im reading different now!!!
__________________
#4 (permalink) | |
Quote:
- http://www.4crawler.com/4x4/CheapTri...line-101.shtml But a CV joint (at least the kind used on Toyota driveshafts) generally have two drawbacks: 1. Less angularity than a u-joint. As noted, even a clearanced or solid axle CV is good for maybe 35 degrees before it binds. A u-joint can probably go to 45 degrees and still work. 2. A CV joint is longer overall than a u-joint. What difference does that make? Well, driveshaft slope is a function of it's rise (vertical height difference) and it's run (horizontal separation of the two ends). Can't change the rise, but by putting in a shorter u-joint on the top, you make the useful horizontal distance longer. Since all the angle change in a u-joint happens right at the u-joint cross bearing, compared to a CV joint where you get part of the angle change at the 1st u-joint section and part at the 2nd section. Other option is to cut and rotate the front steering knuckles for better pinion angle: - http://www.4x4wire.com/toyota/tech/rotated_housing/ Or slap in a high pinion diff (less rise) or slap in a 2nd transfer case (more run), both of which mean less angle on the front shaft. I run both on mine and have almost a perfect front shaft alignment with a CV joint.
__________________
#5 (permalink) |
i ran a High Angle V6 flange on mine until i swapped in a 4cyl case. it allows you to run standard u-joints up front. i'm selling it if you're interested...
__________________
-Mikey- 1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club -> check it yo |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CV Angle | Osep | 03+ 4Runner/GX470, & 05+ Tacomas | 7 | 12-25-2007 05:58 AM |
| Pinion angle + Shackle angle | Island_Yota | Pre 84 Trucks | 1 | 07-28-2007 12:27 AM |
| 1993 Pickup: SAS Death Wobble Problems | Blazen476 | 86-95 Trucks & 4Runners | 1 | 07-19-2006 05:02 PM |
| SAS Driveshaft Problems | lcopelan22 | Offroad Tech | 11 | 09-25-2003 10:36 PM |
| Departure Angle | castrolSi | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-03-2002 04:41 PM |
