pitman arm option
Old 01-01-2014, 03:47 PM
quaz65's Avatar
pitman arm option
i bought a used hi steer kit and it didnt come with a pitman arm. and i was stupid and over looked that the stock ifs one wont work for it . so i was wondering if there is a straight replacement that i could pick up from the auto store/ maybe junkyard or do i have to buy one for a hi steer. also if that is the case has anyone just drilled/press out the tie rod thing and just used the old pitman arm for a temporary solution.
Old 01-02-2014, 01:21 AM
JonnyBoy's Avatar
No other application pitman arm that I know of, you pretty much have to use the high steer pitman arm, or you could possibly use the adapter that SORD makes.
http://www.sky-manufacturing.com/cgi...ey=TOY-PAA-001
I have one, and a flat pitman arm in case I need it, but haven't done my sas yet so I can't give you a real world review yet, sorry.
Old 01-02-2014, 10:55 AM
quaz65's Avatar
ok thanks for the help.
Old 01-02-2014, 04:27 PM
quaz65's Avatar
ok i was looking around on ebay and found a fj40 pitman arm and was wonderin if it will work. it looks the same as the trail gear arm with holes on both ends but I am wondering is there a difference the the steering box shaft.
Old 01-02-2014, 05:14 PM
88_Red_Runner's Avatar
I believe the Sky's Off Road Design pitman arm adapter is only around $30.00. Google sky manufacturing. It will thread into your drag link and has the correct taper for your pitman arm. I have ran one before with no problems. They have some top notch stuff.
Old 01-03-2014, 02:47 PM
quaz65's Avatar
ok thanks i think that is the way i am going to go.
ladybugRC
458
08-21-2020 10:41 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
ktm192k
10-01-2015 08:47 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: pitman arm option
