| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) | |
Quote:
With the '05 and newer tacos you don't to change the oi pan and the steering shaft needs to be changed but the point at which it goes through the firewall does not need to be modified. Also the oilpan is noched on the drivers side in such a way that it seems Toyota knew we were going to do swaps on them. The frame is also notched on both sides that allow for a cleaner application with coilovers. So yes it does matter what year your sasing when it comes to Tacos.
__________________
'05 Tacoma 4x4 TRD Sport SAS Wyatt Scott DeMello-Offroad |
#28 (permalink) |
Skys-manufacturing.com has everything from toyota pickups,4 runners, and TACOMAS reasonably cheap and great products. Doing a 96' SAS and v8 engine swap right now. I've bought the front spring perch, 4 shackles, 4 shackle hangers, and 2 spring hangers from them and probably didn't spend over $300 and found chevrolet 12" springs in the local paper for $400 so hopefully it'll be worth it.
#29 (permalink) |
How does swapping my tranny help with output location for diff offset?
__________________
Ease on down the road. |
#30 (permalink) | |
Quote:
Another option that I'm currently doing is, take a rear FJ60/62 axle cut the ends off and have some mini balls cut down .025 inch press them in and now you have a 66" WHS to WMS 9.5" diff driver side drop Toyota Axle. Or You could take a FJ60/62 Front axle and flip it. You rotate the Balls 180 degrees then cut and rotate the diff cover. The holes for the 9.5" diffs line up no matter where they are so you don't have to drill and tape any new holes. I'm planning to put together a write-up (when I get some extra time) on both of these options as I've done or am doing both. I'm just trying to show people you do not need to use inferior (my personal opinion) Dana axles or spend $$$ on custom axles housings.
__________________
Greg Last edited by yotaman; 08-20-2007 at 09:19 AM. |
#31 (permalink) |
Yeah, but in most cases you can keep your tranny... only have to swap the transfer case.
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's... 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#32 (permalink) |
I'm talking about when doing a Tacoma or 3rd Gen 4Runner SAS.
__________________
Greg |
| Tags |
| 02, 470, 83, axle, cornfed, front, gx, kit, lexus, lift, range, road, sas, tacoma, tacomas, talk, wagoneer |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| lets talk about injector cleaning companies | jayhackett03 | 86-95 Trucks & 4Runners | 17 | 03-22-2007 09:21 AM |
| Lets talk carpet kits | paxil4x4 | General Vehicle Related Topics (Non Year Related) | 1 | 12-04-2006 10:13 AM |
| Lets talk about the hilux surf. | vwfastg60 | 84-85 Trucks & 4Runners | 3 | 10-24-2006 02:18 AM |
| Tacoma SAS | INsr5runner | The Fab Shop | 26 | 04-27-2005 08:43 AM |
| Lets talk Tires for 92-95 P/U - BFGoodrich A/T | CoedNaked | Tires & Wheels | 1 | 10-09-2004 07:14 PM |
