| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ok lets talk SAS on tacoma
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more. My build----HERE More web wheeling- Just getting started so come join us Asphaltsux |
#2 (permalink) |
What year is the Taco?
__________________
~Eric 1991 4Runner 3.0L 4x4 Black, 31" Michelin M/S tires, OME-901's 1992 Lexus SC400 4.0 V8, Green with Tan interior (donor) (PM me for parts) Near Future: FI 1UZ swap. (June) Far Future mods: F/R Lockers, SAS, 35's. UZswap.com - A discussion forum dedicated specifically to swapping UZ engines into Toyota trucks and 4Runners |
#3 (permalink) |
__________________
1987 Mutant 4runner. -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. |
#4 (permalink) |
it shouldnt matter what year it is to sas a taco, right? you are still cutting alot of stuff off the frame.
__________________
- Kyle Former Owner of - 1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06 OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2 |
#5 (permalink) |
I thought only allpro had a SAS kit for the taco.. a IFS eliminator kit for a 86-95 will not work on a Taco...
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's... 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#6 (permalink) |
Super Moderator-Sponsoring Member
Staff
Trail Gear to my knowlege does not have a kit for SASing a Tacoma of any year, only 79-85 pickups and 4Runners. Pickups were not called "Tacomas" until 95.5.
Now if that is what you are doing, let me know and I'll hook ya up. ![]()
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. |
#7 (permalink) | |
Quote:
![]() Its amazing how many people dont know that older toyota pickups are called "pickups".. I have seen many 198x or 199x( pre 95.5) tacoms for sale.. Speaking of trail gear... how long does it usually take to get springs from you? I will be ordering some early next year...
__________________
#8 (permalink) | |
Staff
Quote:
Things go out the same day as the order via UPS ground...3 days to Idaho I imagine.
__________________
#9 (permalink) |
All-Pro and Off-Road Solutions are the only two making "complete" swap kits out there. Both are Coil-overs.
Front Range Off-Road Fabrication and Bent-up both make hanger kits and sell other components to help put together a Tacoma SAS. |
#10 (permalink) | |
Staff
Quote:
__________________
#11 (permalink) |
Is it even possible to SAS a Tacoma?
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#12 (permalink) |
Sponsoring Member
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#13 (permalink) |
Nope, its a myth... kinda like ARB bumpers on a SAS truck
__________________
#14 (permalink) |
We found a few kits. I just need to see if its possible to flip over a front axel from an 85 runner and relocate the breather to the top of the diff housing. If everything turns the same way i dont see any problems doing the swap at all.
My buddy has been trying to find a used D60 but right now doesnt have the money for it. Were going to see if we can make this all happen and if so later on hes grabbing a D60. Anyone know for sure if that woks? Is there a custom housing we could use if it wont?
__________________
#15 (permalink) |
I think if it were as easy as flipping the axle it would be common, and its not...
You have a couple of options, inchworm, marlin and probally others have adapters to put a the xcase from a 85-95 in, giving the option of lower gears, as a well as using a 79-85 axle. You could have a custom housing made, thou if money is the issue this is the way to go... Do you really need 60's on a tacoma? I know some run them, but thats a full size axle, now your needing a 3/4 or 1 ton rear end to match the width... just a whole lot more involved, and a whole different level of wheeling.... Best bet is to get a D44 from a waggoneer, cant remember what years but could be searched, and put that under there. You can get internals for the 44 that make it plenty strong.
__________________
#16 (permalink) |
IF you flip the houseing, you will be putting a lot of pressure on the "Coast" side of the gears when climbing, as opposed to the "drive"s side of the gears. They were not meant to be driven this way, so you won't have the full strength of your Ring and Pinion gears as you should have; when the axle is in its proper location, or right side up.
#17 (permalink) | |
Quote:
Plus, ackerman angle, camber, steering, etc will all be messed up. Go Dana 44 and be done. |
#18 (permalink) |
Yes you can flip the axle..... you'll just have a push-pull rig...
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
Hmmmms Tacomas have pumpkin on the opposite side of a pickup in the front?
__________________
87 Chevy- Flatbed, dana 44 lockright, Custom 10.5 14 bolt lockright, 36 TSL radials |
#21 (permalink) |
yep... which is why the common axle for a taco SAS is a D44
__________________
#22 (permalink) |
__________________
1993 Pickup 22RE 4x4 5 spd. Mods: Engnbldr Street RV Head with 261 C, Trueflow air filter, custom rear bumper, roof rack, 2.25 exhaust from cat back, Thrush muffler, Rancho 5000 shocks, tiny MTRs Future Mods: Diff breathers. Rear locker? Winch? OBA? Flatbed? |
#23 (permalink) |
I'm all about using Toyota axles. I'm SAS'ing a 97 V6 Tacoma right now and I'm using a FJ62 front axle.
You can swap your transmission and then use a Toyota axle if you want. If you have a 4cyl you can use the W56 and if you have a V6 you can use the R151F with a R150 bell housing or a R150 trans. All of these will give you a passenger side drop. So basically you have 3 options: 1. Swap your transmission and use a Toyota front axle. 2. Keep your transmission and buy a Diamond housing ($$$) so you can use Toyota parts. 3. Keep your transmission and use a Dana 44/60. You can use a Marlin/Trail-Gear kit. A number of people over on Pirate4x4 and TORRA have. It's just not designed and marketed for use on Tacoma's. I'd recommend you do a lot of reading on SASing a Tacoma before you even think about doing a SAS on a Tacoma or 96+ 4Runner, it's not as easy as SASing a pre 95 truck or 4Runner. Just a few things that are different on a Tacoma. 1. The steering. 2. The frames are weaker and need plating.
__________________
Greg Last edited by yotaman; 04-21-2007 at 09:52 PM. |
#24 (permalink) |
save youself the reading, and go check out toy4x4.com
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#25 (permalink) |
oops, toy4x4.net
not .com
__________________
| Tags |
| 02, 470, 83, axle, cornfed, front, gx, kit, lexus, lift, range, road, sas, tacoma, tacomas, talk, wagoneer |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| lets talk about injector cleaning companies | jayhackett03 | 86-95 Trucks & 4Runners | 17 | 03-22-2007 10:21 AM |
| Lets talk carpet kits | paxil4x4 | General Vehicle Related Topics (Non Year Related) | 1 | 12-04-2006 11:13 AM |
| Lets talk about the hilux surf. | vwfastg60 | 84-85 Trucks & 4Runners | 3 | 10-24-2006 03:18 AM |
| Tacoma SAS | INsr5runner | The Fab Shop | 26 | 04-27-2005 09:43 AM |
| Lets talk Tires for 92-95 P/U - BFGoodrich A/T | CoedNaked | Tires & Wheels | 1 | 10-09-2004 08:14 PM |
