Longfield Birfs - Race wont come out
Old 05-14-2007, 08:58 AM
azonecam's Avatar
Hey all, I'm doing my first SAS on an 87 runner. When I took the 85 solid axle apart to rebuild it I got the birfields separated but the inner race and bearings are REALLY tight and don't want to come out. My chilton says to just tilt the race and pull the bearings out, but these are not even close to coming out that way - any suggestions?
Thanks,
Jason
Old 05-14-2007, 11:20 AM
tc
tc's Avatar
Um - why are you taking them apart? Are they REALLY Longfields, or just stock birfs?
But yeah, if you wanted to (and I don't see why) - you would push the retainer part at an angle until the bearings come out.
Old 05-14-2007, 12:49 PM
azonecam's Avatar
Well - it seems the only way to clean and repack it would be to take it apart. As for whether they are really longfields, I'm just going by the LF on the bell. If there's a better way to clean and repack them without taking out the cage and race, let me know.
Attached Thumbnails Longfield Birfs - Race wont come out-birf_lf.jpg   Longfield Birfs - Race wont come out-birf_ringed.jpg
Old 05-14-2007, 01:41 PM
waskillywabbit's Avatar
IMO I wouldn't take them out.
Spray them with some brake cleaner real good after wiping off the excess grease, let them dry, pack with new grease and work it in.
Old 05-14-2007, 01:43 PM
azonecam's Avatar
Hey - sounds like less work for me - thanks for the fast replies!
Old 05-14-2007, 06:29 PM
tc
tc's Avatar
x2, although I would soak them in parts cleaner first, try to get as much grease out as you can, then hit them with the brake cleaner. If you use any water, be sure to hose them down with WD40!
And I don't think those are Longs - the ones we got from him for Molly's truck were almost polished. From the pix, yours look to have the (surprisingly) rough OEM machining.
Old 05-14-2007, 09:07 PM
superjoe83's Avatar
those are longfield stock treated birfs with the ring welded to the bell, thats why you cant take them apart, the welded ring is blocking the balls from coming all the way out
Old 05-22-2007, 07:25 PM
Sonofmayhem's Avatar
NO that stands for LeftFRONT
Old 05-22-2007, 08:10 PM
azonecam's Avatar
Ok, if the other one said RF I would have said I had one LongField and one RodneydangerField, but they both say LF
Old 05-22-2007, 08:15 PM
Lysmachia's Avatar
Then I go for this answer.. meaning they are not Longfields originally but have been cryo-treated by Bobby Long... But that will explain why you can't get the bearings off!
BTW - LMAO on the Rodney Field's....
Old 07-16-2007, 10:09 PM
drew303's Avatar
Does bobby still take stock birfs and treat them? I read a looong time ago he did this for like $100 a birf... but i forget where i read that (maybe pirate).
on the site he only sells his..
anyone know?
1uzRunner
63
11-10-2018 03:58 PM
justdifferentials
14
06-11-2017 08:36 PM
Boomer8404
09-24-2015 01:12 PM
superdogg2014
Domestic Swaps
09-19-2015 09:13 AM
AustinTaco
09-18-2015 08:58 PM
Quick Reply: Longfield Birfs - Race wont come out
