YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-10-2008, 01:37 PM   #1 (permalink)
90_4runner's Avatar
Landcrusier axle Questions help
K i just now bought the trail gear ifs eliminator kit and now i have one more ? before i start doing my conversion on my runner.
i bought a 1976 landcrusier axle for my swap but im not sure if the 76 landcrusier axle is any different from the regular 79-85 axles. Because my kit comes wid the knuckle services kit and im wondering if it'll fit perfect. and also about the steering pitman arm from landcrusiers is located different then the 79-85. Help me please b4 i start working on my car. thanks
90_4runner is offline
Sponsored Links
To remove this ad, register today!
Old 06-10-2008, 01:44 PM   #2 (permalink)
Staff
Elvota's Avatar
I don't know the LC stuff very well... but I think you are going to find that not much of a standard SAS kit will be compatible.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 06-10-2008, 01:58 PM   #3 (permalink)
Staff
Yoda's Avatar
The knuckle kit, and wheel bearings are the same. My son and I trade spare parts all the time.
The steering arms may not be compatible. 76-79 used a smaller bolt pattern. The 79+ cruiser arms had the same pattern as the mini truck. I think the aisin hubs are interchangable (early cruisers has a slightly different length birfield)
The axle itself is different than the mini. It uses the landcruiser gears (bigger than a mini)
We are doing a lift on my son's 85 with a TG kit if you want me to make any measurements between my cruiser and his mini.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is online now
Old 06-10-2008, 08:05 PM   #4 (permalink)
Staff
Yoda's Avatar
Just remembered, the Landcruiser is spring under, the mini is spring over
__________________
David
TLCA 14788
Yoda is online now
Old 06-10-2008, 08:23 PM   #5 (permalink)
AxleIke's Avatar
Diff is different (larger).
Also Not sure how the brakes work for that.
Should work though, just check the widths, as the LC axle may be narrower or wider than you want for the rear, so you'd need to space accordingly with wheel spacers.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 06-11-2008, 12:59 AM   #6 (permalink)
90_4runner's Avatar
Quote:
The steering arms may not be compatible. 76-79 used a smaller bolt pattern. The 79+ cruiser arms had the same pattern as the mini truck. I think the aisin hubs are interchangable (early cruisers has a slightly different length birfield).
Well thanks alot YOTA! now i shouldn't worried about the knuckle service kit and bearing now. but about the steering pitman arm i just hope that it'll fit. and yeah the perch is already convert to the top of the axle already when i bought it. and the hubs is WARN brand so it should be good.
Old 06-11-2008, 01:02 AM   #7 (permalink)
90_4runner's Avatar
as for the brake lines im not sure too because on the axle two sides come and connect in the center of the axle to make it one so im not sure on that too.
Old 06-11-2008, 08:53 AM   #8 (permalink)
AxleIke's Avatar
With the brakes I was referring to your IFS eliminator kit, which I know comes with rotors and the like, but they are set up to go on a mini truck hub, not a LC hub. They may be the same, but I'm not sure how the LC rotor is in comparison, so you might end up having to reuse the old brake stuff.
__________________
IFS SAS
AxleIke is offline
Old 06-11-2008, 10:15 AM   #9 (permalink)
90_4runner's Avatar
well a friend of me told me that the rotors from trailgear is LC rotors so it should fit , if its doesn't then i'll just reuse the old ones.
Old 06-11-2008, 11:17 AM   #10 (permalink)
customcruiser's Avatar
I did a fornt disc brake conversion a few years back on a 71 fj40.....
I used all mini truck parts
cant remember if I used the knuckles or not but I used:
birfs
backing plates
spindles
bearings
brakes
rotors
hubs
__________________
94 4Runner Truggy
60/14B, 3Link w/18" Air Shox
Chopped & Exo'd
42's on H1 Beadlocks
Pirate4x4 Build Thread
03 Tundra Crawler Hauler/Baja DD
3" Lift, Fiberglass Fenders
Prerunner Bumper, (3) 9" Lights
customcruiser is offline
Old 06-12-2008, 02:18 PM   #11 (permalink)
90_4runner's Avatar
birfs
backing plates
spindles
bearings
brakes
rotors
hubs
thats kool then! i should have no problem then. thanks guys
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
CV Axle questions Boot vs entire axle? Quality? BornChaos 95.5-2004 Tacomas & 96-2002 4Runners 19 02-28-2008 02:10 PM
Axle Questions kswann 86-95 Trucks & 4Runners 10 02-19-2008 08:04 AM
need help with landcrusier wheel norcalsvx General Vehicle Related Topics (Non Year Related) 5 06-23-2007 01:40 AM
cv axle questions excableguy 86-95 Trucks & 4Runners 4 10-10-2006 08:24 PM
1964 Landcrusier FJ40 - $10900 safado4 Vehicles - Trailers (Complete) 1 08-22-2006 01:48 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
