Keeping rear coils, AP kit spring height?
Old 03-25-2007, 02:28 PM
chimmike's Avatar
So I'm running the Option #1 https://www.yotatech.com/forums/show...ght=trdparts4u
but I don't have the rear coil spacers installed as the HD springs are pretty incredibly tall and they weren't needed.
I figure another 2" of rear lift when adding the coil spacers.....so with the all-pro off road kit (on my 31x10.50's) http://allprooffroad.com/index.php?o...ask=view&id=42
Should I do the 4" or 5" lift springs? Also, is it worthwhile to upgrade to the 5150 Bilsteins vs. the 5100s?
I don't plan on doing the rear leaf conversion quite yet, I've got a bit of work ahead obviously to complete the front, so I'm not going to consider that yet....aside from the fact that I'll need new gears and a locker in the new axle.
Old 03-27-2007, 07:14 AM
chimmike's Avatar
wow, that's wild. I posed this a couple days ago and it just appeared yesterday! lol
Old 03-27-2007, 07:40 AM
Marc P's Avatar
I am running long side LC coils, All-Pro adjustable upper links, an adjustable panhard bar with panhard drop bracket, and my front is still a little higher.
I would not waste too much money on the rear coil setup. Eventually you will need to do a leaf conversion to make it right....I know I need to soon.
Old 03-27-2007, 08:10 AM
chimmike's Avatar
so you kinda pieced together your SAS parts rather than buying a kit, I see.
Is it working well for you? What did you use for steering?
smthwsn357
05-01-2024 07:28 AM
jerusry
10-19-2015 05:28 PM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Keeping rear coils, AP kit spring height?
