J-arm stuck on axle?? wtf?? help
Hey guys
Doing a SAS on a '90 4runner and I'm having a little trouble getting the J-arm off the 85 front axle. Got the passenger side off easy and installed the hi-steer arm on that side. The drivers side is loose and I can pull the j arm up about ~.25" then it stops and won't go up anymore. Cone washers are out, studs don't look bent (but i guess they could be). I tryed prying it upwards GENTLY but I didn't want to hurt anything
Any ideas? anyone ever have this problem before?
Thanks
Joe
Thanks
Joe
very common on stock axles that have never had the kingpin bearing replaced. hope you have a spare kingpin bearing as it will be ruined after you beat the arm out.
polo451
13
11-20-2016 07:49 PM
ripp96
07-31-2015 11:14 AM
