help me stiffen my springs
hello i have posted a few times on here but i have a problem. i have a trail gear sas kit and everything was fine until the springs broke in, i hit my bumps all the time even going over speed bumps and braking, i dont want to shorten the bumps cause when i flex the spring will bend in a negative arc. i have been thinking of adding a leaf to the front pack question is where? i was thinking under the first two mains and have 3 leaves that are full lenghth. i have a set of 81 rears that i have in the shop i can hack or swap in. any ideas would be great. also i switched to rubber bumps i got from the yard and that helped with the spinal jam when i hit the stops but my springs are 220 in pounds and am just looking to stiffen up the pack a little thanks guys ant help will be apreciated
I know a lot of people that use the rears up front make a bastard pack from the ifs rears and Jeep Wagoneer springs. I hope that helps.
Spring Info Chart
Spring Info Chart
live4soccer7
05-11-2016 06:52 PM
