front axle
front axle
i hav searched but i couldnt find anything on the old 80 model suburban front axle i found one in a scrap yard and i was wanting to know if it would work what do yall think
not sure half of the body was gone which one should i b looking for cause yota axles r very few and far between round here so chevy axles r very easy to come by
well either way the front end out of any suburban will be really wide weather it is a 3/4 ton k20 or a one ton k30 you will not be stret legal. unless you plan on building a dedicated trail rig get a toy axle,
I wouldn't a d44 is much weaker than a toyota axle.
I would check www.craigslist.com in your area. Find a 85 and older toyota someone is selling as a parts vehicle.
It could be a good axle. It's probably a Dana 44 and might have flat top knuckles for a high-steer. Should be spring-over-axle. Wheel bolt pattern will match the rear Toyota axle. It's way too wide, of course, but it's not really that hard to narrow one. There are how-to's all over the web about how to narrow an axle.
FYI: Scout axles are a really bad idea for a swap. Axle tubes are smaller diameter than any other Dana 44, diff housing is cast for spring-under-axle, knuckles aren't flat-top, low steer arms are too long for the Toyota IFS steering box, caster angle is zero degrees. It's easier and cheaper to buy a Chevy axle and narrow it (or stick with Toyota...).
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
