Dana Performance for LandCruiser
Old 08-18-2016, 04:01 PM
gkanai's Avatar
Dana Australia has a new Dana 60 for the 70 Series.
http://danaperformance.com.au/dana-p...r-landcruiser/
  • Retains the full-float design; vehicle weight is carried by housing for greater load-carrying ability
  • Original axle centre offset with 95mm wider overall track – no wheel spacers required
  • 30 spline larger diameter forged 1541 steel alloy axle shafts
  • Selectable electronic locking differential – genuine Eaton E-Locker™
  • Heavy duty 9¾” (248 mm) ring gear
  • Massive 3½” (89.9mm) outside diameter 0.390″ (10mm) wall thickness axle tubes
  • Heavy-duty suspension brackets – ready for your heavy-duty suspension upgrade
  • Nodular iron diff cover
  • Spicer® 1350 Strap-style/Half-round end yoke
  • Heavy duty Spicer™ drive shaft
  • Designed to re-use the original vehicles brakes, ABS, wheel hubs and wheels
NDcrawler
02-27-2019 04:52 PM
1985 4Runner
03-02-2016 10:24 AM
AustinTaco
02-27-2016 07:27 AM
Jamie Mello
02-11-2016 09:11 PM
LoflandJ
02-03-2016 05:49 AM
Quick Reply: Dana Performance for LandCruiser
