2wd 87 pickup sas
Old 06-15-2016, 05:18 PM
J_benton123's Avatar
2wd 87 pickup sas
Hey I have the money for parts and everything I just had a few questions about mix matching a 89 4x4 rearend into an 87 2wd pickup with and 84 or 85 front axle and how hard it would be? Maybe some tips for when I go to try it?
Old 06-15-2016, 05:53 PM
Fossilized
Staff
dropzone's Avatar
Read the threads in the SAS folder
Make sure both gear sets match
Old 06-15-2016, 11:46 PM
wyoming9's Avatar
Sell your 2wd truck buy what you want .
Since your ahead to buy a complete truck rather then parts here and there spending lots of time and $$$ running after things
Then it might be easier to just swap this engine into a 4x4 that only needs a engine.
If your doing this for something to keep you out of the house keep the spouse from spending money .
No real pressure maybe a year or two time line forgetting it done.
Have a good time.
Fabrication skills up to the job.
Having fixed a few of these over the years that the builders got things a little off and the truck went down the road a bit sideways
Old 06-16-2016, 04:18 AM
I was gonna run 2wd till I could get the shaft made then worry about gearing both of them
Old 06-16-2016, 04:19 AM
Have a good time.
Have thought and thought about this that's why I got on here to see how hard the swap would be I don't care how long it takes just didn't know how troublesome it would become because I'd like to make it fuel injected as well while I'm at it
Old 06-16-2016, 04:34 AM
Staff
Terrys87's Avatar
Buy one that is already fuel injected. I have converted trucks from fuel injected to non fuel injected and there are numerous things involved besides just putting in injectors and the Plenum. Just because 85-95s were fuel injected doesn't mean all the years interchange and especially when dealing with two different generations of trucks.
Old 06-16-2016, 12:36 PM
wyoming9's Avatar
Not trying to rain on your parade here.
First the conversion to 4 wheel drive .
The transmission and transfer case front and rear drive shafts
most likely build a custom cross member depending on if your going auto or manual
Then front and rear axles it might be possible to change the rear axle shafts or have them redrilled for 6 studs instead of 5 be a pain 6 lug wheels on front and 5 on the back
Lots of little details one forgets
Then the SAS completely remove the front suspension .
Rebuild your new front axle and front brakes Install the spring hangers and shackles
install the steering linkage and steering box.
Get the front end aligned
Plus lots of other little things .
Kevslatvin
02-23-2016 04:44 PM
Ifoundyoda
02-19-2016 08:56 AM
Camorunner
02-14-2016 07:49 AM
lilwily
17
10-29-2002 08:38 AM
rowan
12
07-31-2002 08:29 PM
Quick Reply: 2wd 87 pickup sas
