FJ Cruiser 2007 & on
FJammer w/Sub..AM/Sat button won't show SAT.
Old 02-25-2012, 08:20 PM
old4x4's Avatar
I have an '08 FJ I just purchased That has the FJammer sustem with the Subwoofer option also. It also has the 'Upgrade Pkg 2' based on the options it seems to have. Problem is, the AM/Sat button only shows AM when pressed. Did this pkg automatically come with the satellite receiver installed? I noticed a Sirius antenna on the roof over the rear of the truck. Anyone know?
Old 02-26-2012, 02:05 AM
Co-Founder/Administrator
Staff
Corey's Avatar
More than likely you do not have a satt installed.
I no longer have the stock radio, but it too had the satt button on it.
If you have an aftermarket satt receiever one installed, then the satt button should work.
If there is an antenna installed, looks like the previous owner took the satt unit, but left the antenna.
ManzDaKlown24
08-22-2015 10:25 PM
JHalcyonM
08-04-2015 01:19 PM
Daneums
07-28-2015 11:57 AM
RustBucket
07-24-2015 04:46 AM
msane99
07-11-2015 08:08 PM
Quick Reply: FJammer w/Sub..AM/Sat button won't show SAT.
