disappointed that MT FJ is full-time 4wd.
If the MT FJ was part-time 4wd like the AT, I would have ordered one. But now I'm on a holding pattern and I'm being pressured to get the AT so that everyone else can drive it. Why didn't Toyota offer the MT in PT 4WD?
Having lived with all of the Toyota 4X4 systems, I'm grateful FJ M/T has FT standard. The expensive locking center Torsen and RR locker both come standard with the M/T. To think it's priced lower than the less versatile PT system is icing on the cake. The M/T FJ is unique. There's no other Toyota or Lexus available with that drivetrain and RR locker. My 2¢, but I'm biased and ordered an M/T because of the FT, shorter gears and lighter weight, not to mention if given a choice will always get an M/T for the fun factor.
And unless "everyone else" is helping with the payments, who cares what they think ? Get what you want !
Steve
Steve,
some believe that with a PT system you save more $ compared to a FT system. But looking at the 4th gen 4runner's it doesn't look like there is much of a big difference compared to the FT and the PT system. Of course we have to factor in the v8/v6 change but even with that in place, it's still minimal.
Originally Posted by snap-on
what about gass millage between the 2?
between the FT/PT and MT/AT thing? .... any thoughts?
I would have got a manual, bit I have been spoiled by my 4Runner since '98 with its auto.
Plus I prefer auto off road.
Not as easy to coast back on a steep hill.
The 4Runner was my very first auto tranny, and it is nice not having to shift.
Now if I had a sports car or a 60 to 70's muscle car, then yeah, stick all the way.
I also noticed that all of the FJ extreme off-road videos sound like A/T's. Plus, if I had a freeway commute, I'd get an A/T. Luckily, I'm surrounded by smooth two-lane mountain country roads and my commute is to the coffee pot, so the choice was easy.
The difference in the FJ you'll see from the different gear ratios I think.
I will bet that a few years down the line both the A/T and M/T will have the full time 4WD transfer case.
Lance is correct in terms of the fact that numerous peole have run their V6 4R in 4WD or 2WD with the PT case and have recorded very little change in gas mileage. Please keep in mind that the PT TC on the 4R can be used as a FT 4WD as well, since it has a torsen center diff. It completely baffles me the way they have set up the FJC though, they should have just reused the V6 4R case with a lever instead of electric shifters. This would have given the ultimate flexibility with 2WD 4Hi, 4Lo, 4hi locked, 4lo locked.
Bob, I did not know about the AI in the auto tranny.
What will they think of next?
You would think that Toyota is reading the forum here
That is cool though.
It will learn my driving habits, which is nice and easy, almost grandpa style
I am a very conservative driver.
Nahhhh, it will be nice to drive a vehicle that handles traffic much better than my tired rig, and will pass someone if the need arrises.
Edit: Andries, did I understand you correctly in the fuel tank placement thread? Is the 4Runner mid-mount style what you hoped for?
Originally Posted by BT17R
How about no maintenance, ever? There's no longer even a tranny dipstick. The super long life coolant is slick, too. 100K for the first change. Then the 12-hole injectors, hmm, OK I'll shut up...for now.
This is all news to me
I wonder if it is worth going Amsoil in the auto tranny and transfer case?
I would like to do the diffs and then the engine after it breaks in.
Originally Posted by Good Times
Steve,
Steve
Really? When did that happen? I thought the Torsen was V-8 only?
They did in the A/T models. They're just as you describe with console mounted t-case and e-brake levers.
The way I read the literature on the FJC is that the A/T will not have a center diff, only the M/T. This means you can't run the A/T in 4wd all the time. I was hoping they would just use the 4R transfer case with a manual lever, so you have the choice of running in 4Lo without the center diff locked. Strange thing is that it is availible on the LC100 and GX/LX 470, but with the 4R we have to fiddle with dash switches for 4H to 4L. The FJC, which is marketed as the most capable offroad, it misses some nice features which would have been easy and cheap to put in. Maybe it is an easy fix on the M/T, like the LC 80s. Not a real big deal, just would have been nice.
About the 4th Gen, I only paid attention to my V-8 and thought the V-6 was PT for some reason, Right you are.
About FJ, I was only commenting on the console mounted t-case lever.
About fuel tank placement? I wasn't clear what's considered the most desirable location, in front of or behind the rear axle?
So I don't know why they didn't do it on the FJC. Using the tank behind the axle you tend to loose the low hanging tank syndrom of the 2nd - 4th gen 4Rs. Easy enough since you spare sits on the door.
Oh well it is what it is, love it or leave it. I personally would have prefered a 3dr Prado 120 platform directly leveraged with the FJC body & styling. At the moment it weighs the same as the V6 4R and there is not much difference in dimensions with the same suspension.
