600 lbs for the hitch?
Typically the hitch load is 10% of the rated towing capacity (15% Max.). That being said, if the total weight of the bike and the carrier is 600 lbs. you might be o.k. since the weight is so close to the rear axle.
DEWFPO
DEWFPO
Maximum tongue weight is listed in the owners manual, it is probably 500lbs. You could probably get away with it, but the rear end will really sag. Suspension airbags would probably work pretty well in this situation.
choppe777
05-16-2016 08:00 AM
FS[MidAtl]: fZJ80 9.5" rear axles w/ e-lockers complete
I8URSVT
10-05-2015 07:23 PM
mirabile4runner
09-03-2015 07:15 AM
