Advice on Finding a Short - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Sign in using an external account
Register Forgot Password?
93-98 T100s All T100 trucks
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-19-2012, 07:58 AM   #1 (permalink)
Personal Sales Rating: (0)
Hi Guys!
So this post is an extension of an older one (erratic cold idle). I have finally been able to conclusively determine that the reason why my truck is idling so erratically is that there is a short between the engine coolant temp. sensor and brake circuits (not sure which brake circuit, just know it has to be one that gets powered when you hit the brakes). Does anyone have any good advice on finding this short. I have a service manual with a wiring diagram already. Just wondering if there is any way to locate it without having to try to trace the wires up over around and through everything the engine bay.
FoCo_4_Low is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-21-2012, 06:25 PM   #2 (permalink)
5 Year Member
You wouldn't happen to have a trailer light adapter installed would you?
Have you tested the brake switch yet? Do you have cruise control?
BamZipPow is offline
Old 02-21-2012, 07:18 PM   #3 (permalink)
Threadstarter [OP]
I do have a trailer light adapter and cruise control. Brake switch? Would that be the one operated by the pedal to turn the lights on?
Old 02-24-2012, 02:23 PM   #4 (permalink)
5 Year Member
The trailer light adapter could be shorting out and causing yer electrical gremlins. Try removing the adapter and see if the problem still exists. Those adapters are a known electrical gremlin creator...when they go bad.
Those vehicles with cruise control vs those that don't have a different brake light switch. You must make sure you replace it (if it's bad) with the same type. A non-cruise control brake switch won't work...
Yotatech
4WD Truck
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
