General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
wiring harness compatibility 88 4runner
Old 06-19-2013, 10:15 AM
Trex's Avatar
Hey guys, So I have a 1988 toyota 4runner that needs a new wiring harness. I'm wondering what year harness' will be a direct replacement? will 86-88 harness' be the only option? or could I use any of the 89+ harness'? I mainly just need the interior harness. any info would be awesome. thanks!
Old 07-18-2013, 01:48 PM
Hadmatt54's Avatar
What engine do you have? 22-re or 3Vz-fe. If you have a 22-re it depends when your 88 was manufactured! Prior to August of 88 the 22-re had low impedence injectors with a resistor pack located on the passengers side inner fender, but the wiring for this is in the cab harness that comes out through the inside of the fender. If yours has this then the 86-88 harness should work but Toyota likes to move wires around from different models and different years, so you will have to trace out the connector pins to make sure they are the same. After August of 88 Toyota went to high impedence injectors and removed the resistor pack, if your 88 is this type 89-94 will probably work, but again you will have to verify pin configuration. I think the 3vz's were pretty much the same, but you have to check connector pin configuration!
Old 07-18-2013, 10:27 PM
wyoming9's Avatar
Red face
Just how bad is yours??
While Toyota tends to use the same colored wires across the years it may be a real project to merge the two harnesses .
Old 07-18-2013, 10:34 PM
Staff
Terrys87's Avatar
The harness seperates into 3 or 4 sections. Which part is bad? There are several differences. 85/86 diagnostic port on driver side, 87 and up diagnostic port is on passenger side, 88 is the odd ball year for injectors. 90 and up is a different body style so not sure if all the connectors are the same.
Old 07-20-2013, 01:01 AM
wyoming9's Avatar
Red face
Maybe we asked to many hard questions .
Didn`t give the answer they wanted to hear.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Regency
20
01-03-2020 07:43 PM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: wiring harness compatibility 88 4runner
