Tacoma Horn Gremlin HELP!!!!!!
Well its always something! Tonight I get in my truck and start. When I turn on parkinglight/ headlights the horn sounds. This also happens with engine off. I gave the truck a good exterior rinse today but did not go under hood. Have any of you ever had this gremlim? Everything else seems fine and horn works normal when lights are off. Any help would be great! Pete
Horn Gremlim..its great at weddings!!
As I had mentioned in first post, I had rinsed pretty good the frame and undercarriage blasting the hose up into fender openings to attempt to remove road salt and got a connector wet causing horn problem. I'm dry again and my neighbors are dropping all charges. Thanks for any and all help! Pete
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
charlie_fong
09-27-2015 10:06 PM
