General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Question on running dual batteries (different than usual...)
Old 03-25-2006, 12:41 PM
Keggo's Avatar
After doing my H.I.D. retrofit my 12V battery is too big and pushes on my passenger side headlight. Anyway, my question is this... I'm thinking of running dual inline 6V batteries. My main reason is because there really isn't enough room to relocate my current battery anywhere else. So, I figure, if I have an Optima 6v in the stock battery tray and one mounted closer to the cab, in theory it should work fine,right? As long as I wire it: chassis ground to battery 1's negative -> battery 1's positive to battery 2's negative -> and then have battery 2's positive to starter and fuse box (stock routing). Does this make sense?
Or should I route wires for each battery seperately to the fuse box and starter?
Old 03-25-2006, 06:44 PM
L33T35T 4Runner's Avatar
you would have to hook them in series, thats -
ground to negative 1 (battery 1), positive 1 to negative 2. positive 2 to starter fuses, etc. this will increase your voltage (giving you 12 volts) but keep the same amperage of one battery.
if you hooked them in parallel, that would be negative1 to negative2 to ground, and then positive 1 to positive 2 to ground, that would only give you 6 volts, but twice the amps.
Old 03-25-2006, 06:56 PM
superjoe83's Avatar
couldn't you just get a slightly smaller battery?
Old 03-25-2006, 07:00 PM
4x4Lamm's Avatar
Maybe a battery relocation kit? Put it in the back or something...
Lamm
Old 03-25-2006, 07:17 PM
shawn0890ss's Avatar
yeah that would be awsome to do a dual baterys in toolbox in the back like waskillywabbit did. he has pics on his website showing you how it looks
Old 03-25-2006, 09:44 PM
Keggo's Avatar
Yeah, that's exactly what I had planned. I just want to make sure they'll be charged evenly. What gauge wire should I use? Like 2ga. stranded, right?
Old 03-26-2006, 07:23 AM
the thicker the better
Old 03-26-2006, 10:19 AM
Keggo's Avatar
Cool!
Old 03-29-2006, 03:54 AM
GSGALLANT's Avatar
Don't forget to check the amperage rating on your 6V batteries. They may not be sufficient to handle the job.
Old 03-29-2006, 03:16 PM
Keggo's Avatar
Cool... thanks!
Old 04-09-2006, 09:00 PM
AH64ID's Avatar
That should be pretty cool. Lots of extra weight though. I think you could move the battery tray a little for a lot les hassle and $$$. Move one 12v battery to the back of the rig??
If there is no room to relocate where are you going to put the second 6v??
And where did find a 6v optima, I was just on their site and couldnt find one.
Old 04-09-2006, 09:33 PM
Keggo's Avatar
They only have the red top 6v's. Also, I heard with having at battery too far away from the starter kind of causes some cold start up problems...
Old 04-09-2006, 09:58 PM
AH64ID's Avatar
As long as you upgrade the wiring to the starter you shouldnt have a problem.
Its still a big battery, just half as wide. I still think it would be easiest to move the battery aft about one inch.
What is so much bigger with this coversion? Isnt the washer fluid resivour in between the battey and the headlight?
Old 04-09-2006, 11:22 PM
surf4runner's Avatar
the batteries should match (of the same capacity) for charging purposes
Old 04-10-2006, 03:04 PM
85TurboRunner's Avatar
just get a braille battery http://www.brailleauto.com/
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Question on running dual batteries (different than usual...)
