YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Electrical & Lighting Related Topics
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-19-2008, 02:06 PM   #1 (permalink)
JCM4x89pu's Avatar
Send a message via Yahoo to JCM4x89pu
Exclamation HELP! electrical problem
i'm having some electrical problems with my 89 pickup...
..when i turn the truck on, all of the lights on the instrument panel are lit up (the parking brake light, low batt light, & a/t oil temp light)... my battery is fine, my parking brake is off, and my a/t is not hot.. also, the backlight on all the guages is dimmer than usual... any ideas??
__________________
1989 4x4 v6 pickup
****HUMMER RESCUE VEHICLE****
auto
251,872 miles.
driven hard like a toyota truck should be.
31 x 10.5 bfg at's, well taken care of 3vze, rebuilt Hi-Track IFS, delrin/teflon composite control arm bushings, redesigned 25mm BJ spacers, manual hubs, cat replacement & 2.5" exhaust with flowmaster muffler. Marlin bumpers, e-locker mod, various engine mods. LCE headers, too many custom made mods to list.. she goes anywhere i point her.
JCM4x89pu is offline
Sponsored Links
To remove this ad, register today!
Old 05-19-2008, 02:29 PM   #2 (permalink)
89dlx's Avatar
All your lights coming on when you turn the key on is a "bulb check". If the lights are on when it's running you have a problem.
Dim lights means some of the bulbs are probably burnt out.
89dlx is offline
Old 05-19-2008, 02:53 PM   #3 (permalink)
JCM4x89pu's Avatar
yeah... the lights are on when its running.
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Old 05-19-2008, 03:08 PM   #4 (permalink)
89dlx's Avatar
bad alternator, happened to me.
89dlx is offline
Old 05-19-2008, 03:14 PM   #5 (permalink)
Team420's Avatar
^ x2 bad alt.
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Old 05-20-2008, 12:46 AM   #6 (permalink)
JCM4x89pu's Avatar
i tested the alternator, and it is well within specs... i can see why the dim backlight would be a symptom of a bad alternator.. but do the parking, at oil temp, and batt lights come on with a bad alternator? i dont understand why it would do that. i think it is a problem with the wiring... not to undermine you guys.. thanks for the help.. i just want all the info i can get before i go replacing things.. any other ideas?
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Old 05-20-2008, 12:50 AM   #7 (permalink)
JCM4x89pu's Avatar
the alternator is putting out almost 15 volts at idle... and the lights on the dash only come on intermittently.. then go away.. then come back. and the backlight on the instrument panel is only dimmed when the dash indicator lights come on.
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Old 05-20-2008, 03:35 AM   #8 (permalink)
89dlx's Avatar
My alternator was charging also. But something in the alternator is going bad and I did not want to drive around knowing I might get stranded. The lights came on as I was driving down the highway. I parked the truck and changed the alt. the next day. (good thing NAPA is 2 minutes away if you walk).
89dlx is offline
Old 05-20-2008, 08:20 AM   #9 (permalink)
JCM4x89pu's Avatar
ok.. so the lights coming on are like a warning for a bad alternator?.. kinda like a check engine light for your charging system? thanks
...ps.. i know my starter has gone bad (not due to a lack of charge.. it cranks fine when i hit it with my lug wrench.. so, solenoid right?).. is there any way that a bad starter can cause the same symptoms?.. if the brushes & contacts are worn also?
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Old 05-20-2008, 08:46 AM   #10 (permalink)
JCM4x89pu's Avatar
nevermind... you guys were completely right.. bad alternator.. battery is dead this morning.. now i get to replace my alternator, and starter contacts yaaaay haha thanks for all the help!! anyone want to come fish a starter out of the 3.0??! haha yeah right
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Old 05-20-2008, 12:29 PM   #11 (permalink)
JCM4x89pu's Avatar
cool, it took me about 20 minutes to replace the alternator. runs just fine, no more lights, no more dim backlight. THANKS GUYS!!!
i"ll wrestle the starter tomorrow
__________________
1989 4x4 v6 pickup
auto
251,872 miles.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Help with electrical problem montanatoy 86-95 Trucks & 4Runners 1 08-10-2006 04:23 PM
Electrical Problem edsglobal 95.5-2004 Tacomas & 96-2002 4Runners 1 07-02-2005 01:02 PM
Electrical Problem... TMcLeod 95.5-2004 Tacomas & 96-2002 4Runners 14 02-08-2005 05:49 PM
Electrical Problem Help RkyMtn_Toy 95.5-2004 Tacomas & 96-2002 4Runners 3 02-27-2004 08:50 AM
Do I have an electrical problem? jimrockford 95.5-2004 Tacomas & 96-2002 4Runners 2 08-07-2003 09:50 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
