| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Gm Cs144 (140 Amp) Alternator Swap On 3.0
__________________
------------------------------------- If it's not broken, it hasn't been modified enough. pickup 91 3.slo,along with "the money draining mod" PROJECT SAS UNDER CONSTRUCTION MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!! http://www.yotatech.com/f116/yet-ano...s-pics-155676/ |
#2 (permalink) |
but theres a small bug here i found out : why the hell is there 4 wires in gm pigtail wire and 3 connection on toyota one???
witch wire to dump? how to know? thats the GM pigtail wire:
__________________
------------------------------------- If it's not broken, it hasn't been modified enough. pickup 91 3.slo,along with "the money draining mod" PROJECT SAS UNDER CONSTRUCTION MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!! http://www.yotatech.com/f116/yet-ano...s-pics-155676/ Last edited by Chief_Yota; 06-19-2007 at 05:45 PM. |
#3 (permalink) |
__________________
------------------------------------- If it's not broken, it hasn't been modified enough. pickup 91 3.slo,along with "the money draining mod" PROJECT SAS UNDER CONSTRUCTION MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!! http://www.yotatech.com/f116/yet-ano...s-pics-155676/ Last edited by Chief_Yota; 06-20-2007 at 06:47 AM. |
#4 (permalink) |
You may be able to find your wiring answer here: http://www.nwreg.com/products/Adapte.../Fr_AHMain.htm
If that doesn't work, here's the long way to it: http://www.nwreg.com/products/. Select 'Adapter Harnesses' (by-pass your pop-up blocker if necessary), Keep us posted on how this works out!
__________________
89 4Runner, V6, Auto, Some stuff's stock, some's not. |
#5 (permalink) |
the cs144 is 234 can dollars at local savaria auto part. without core return.
im trying to figure out where i can get that pig tail wire. once i found it ill get the alternator for sure!!
__________________
#6 (permalink) |
alright haha,i got pigtail wire and i got some good news ladies,it only as 3 wires ,how ? dont ask its pretty wierd,i got it from savaria too.
(little update here):its needs some lower bracket extention!!,plus washers on bolt,and he was right about the longer belt ,but else than that its flawless!!.
__________________
------------------------------------- If it's not broken, it hasn't been modified enough. pickup 91 3.slo,along with "the money draining mod" PROJECT SAS UNDER CONSTRUCTION MY SAS BUILDUP AND MUCH MORE FONKY STUFF,check it out!! http://www.yotatech.com/f116/yet-ano...s-pics-155676/ Last edited by Chief_Yota; 08-21-2007 at 08:20 PM. |
#7 (permalink) |
as for how it performs ,well i cant really comment on that cause ive just did the wire upgrade and had no time to make an custom braket.but since i did the wire upgrade i did not had any problems anymore with my system!
so untill i get auxilary lights,or winch,the cs-144 sits in my house waiting to be unleashed! but as soon as i get it together ill pop some pics.
__________________
#8 (permalink) |
and dont worry ive tryed to put it in,it fits just need to take off the flat intake connection,off to put it in cause its BIG,.then you put it back after.
__________________
| Tags |
| 144, alternator, arc, cs, mobi, modification |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| mr2 alternator swap in 3rd gen? | CBDenver | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 02-15-2007 01:41 PM |
| GM 200 amp alternator and dual Optimas in a 98 4Runner (pics) | 98LimitedCustomized | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 07-14-2006 12:16 PM |
| ALternator Swap Questions | 04 Rocko Taco | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-14-2006 12:07 PM |
| New 140 amp Alt came today | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 29 | 07-30-2003 07:02 AM |
| 84 pickup alternator swap with 86 | eroc1313 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-28-2003 10:12 PM |
