General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Full Time Power Outlet Mod
Old 06-26-2011, 07:20 AM
XJeepguy's Avatar
Good morning all .
In this write up > https://www.yotatech.com/forums/f127...4runner-75183/
The jumper wire goes where the two copper terminals were on the relay ? The picture is a little fuzzy and just wanted to be 100% correct here . Going camping in the morning and this will make life a lot easier not having to turn the key on all the time.
Thanks
Old 06-27-2011, 06:49 AM
XJeepguy's Avatar
No one here has done this mod except the author ?
Old 06-27-2011, 08:21 AM
NicCantDecide's Avatar
That diagram makes it look really complicated...
All you have to do is connect the power outlet to unswitched (always on) power. I'd recommend using a fuse tho
Old 06-27-2011, 02:46 PM
XJeepguy's Avatar
I did and used a fuse also , thanks
Old 06-27-2011, 02:51 PM
no prob. The only time you'd need a relay is if you were putting it on switched power. In that case, you'd avoid the switch (ignition or otherwise) from taking all the load. The switch would signal the relay to close and that would channel the current instead.
I've been doing a complete rewire on an old VW Super Beetle the last few weeks so I've been getting a lot of practice with this stuff haha (luckily those things only have about 30 important wires to them).
Old 06-28-2011, 07:35 AM
XJeepguy's Avatar
Haha ya I've done a re-wire on a Beetle once . Was a very early year so it wasn't to bad . What year is the Super B ?
There's a red S-Beetle sitting down the road where I live , been there for 2 years and hasn't moved and I am so tempted to make an offer. Its dusty but looks in really good condition .
Old 06-28-2011, 09:14 AM
It's a 74, the year before they went to fuel injection I believe. It's been a lot of work but it's almost done. The seatbelt interlock system and test connector was over half the harness, but I just cut those out.
marcusSRG
06-27-2015 07:13 AM
yamaha73
06-18-2015 06:19 PM
Quick Reply: Full Time Power Outlet Mod
