General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electric radiator Fan
Old 03-03-2012, 08:03 AM
funcrazy1's Avatar
Hello fellow yotatech members got a question today!
So I have 1980 2wd pickup new radiator in it the fan use to kick in but no longer does. I found out last night due to letting the truck warm up it was almost peek red line on the temp gauge. I was wonderig what the problem is ?
Old 03-03-2012, 08:30 AM
worshipmentor's Avatar
Dependng on the ambient temp outside I'd be REAL CURIOUS how long it idled to warm up before it reached that point?
Did you replace the rad because of leaks or an overheating problem?
If it was cold outside I'd be suspicious of the thermostat or water pump before I was concerned about the airflow.
Electric fan is not stock on that so what is it using to operate it?
Old 03-03-2012, 10:54 AM
funcrazy1's Avatar
I bought the truck like this so i don't know. It was cold out when I was warming it up with a manual choke set at 1.5k rpm. It doesn't over heat when driving . So I was going to test to see if the fan even works cause it did when I first bought the truck. I guess tomorrow my day off i will be chasing wires
Old 03-03-2012, 05:23 PM
funcrazy1's Avatar
It was a bad power wire
voiddweller
05-20-2021 07:58 AM
coryc85
09-09-2015 06:24 AM
Ohio4Runner
08-31-2015 05:45 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
TURBOrunnerNM
07-20-2015 08:31 AM
Quick Reply: Electric radiator Fan
