ecu or not???
ecu or not???
i have an 88 4x4 with efi. somthing seemed to be going bad on it, the batt.& brake light would go on & off randomly or when turning corners then died all together while turning a corner & wont start. 2 shops including a toyota specialist said it was probly the ECU, i tried a 89661-35150 ECU but mine is a -35110.... can anyone tell me if i need the exact #? P.S. they both said the injectors are gettin power but not a ground. i cant find any shorts or breaks. i tried to fire it on starting fluid, not even a fart......
Alt./brake light:
- http://www.4x4wire.com/toyota/mainte...nator_brushes/
Injectors are grounded via the ECU, check the injector wire splices:
Thanks Crawler. This info is just what i needed. Hopefully I can check these soon. I learned a lot on here after I posted that. Seems to be a pretty common problem. Thanks agian. This site is priceless
Boomer8404
09-24-2015 01:12 PM
zz_denis
09-06-2015 03:43 PM
