back-up lights
Those LED lights just don't look very bright.. It may just be that the picture doesn't do the lights justice..
so i have to come to find out that the reason i cant see ANYTHING AT ALL when im backing up at night is because my stock lights arent even coming on all the time.
i went to back out of my girlfriends driveway the other night, i shifted into reverse, turned my head backward to see where i was going and presto! light!....i was amazed because i realized it was either my switch or something wasnt hitting the switch properly in my manual transmission. so i started wriggling my shifter and watched the lights go on and off. but i wasnt leaving reverse while doing this.
so now im wondering whats up with my backup lights, and why they dont always work
Think of an LED flashlight, it's very bright. I'm willing to bet that James Dean's backup lights are plenty sufficient. Looks good, J!
#25
It's not often that you can accurately capture the amount of light given off, halogen or not, LED or not, through pictures. It's tricky to get exposure times correct in a dark situation.
The point I was getting at, which I failed to make clear, is would these be bright enough on a trail, or backing into a driveway with absolutely no other light source? My dim original lights don't work, so I'd be relying strictly on these LED's for reward visibility..
Does the amount of strain you reduce on the electrical system justify the reduced amount of light? The longest at a time I'd be using these lights is 60 seconds at a time, I don't really comprehend the need for energy saving LED's.
and LED flashlights are really bright, but not at a distance I find.. it is probably because they've got a smaller focus point that they don't "throw" light very far
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
