| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
alarm acting up after installing red top bat.
__________________
87 4Runner SR5 - some spacer lift with cranked torsion bars - 31x10.50/15 BFG Mud Terrain KM2 (amazing tires!) 99 4Runner SR5 Highlander-auto - K&N filter, removed intake elbow, open air box, deckplate mod - 265/75/R16 BFG MT's on stock 5 star's - raised rear diff breather 2003 Mach 1 -full bolt ons, 4.10 gears, tuned by Excessive Motorsports; 307 hp, 326 tq |
#2 (permalink) |
OEM or aftermarket?
If it's aftermarket I would start by going to the installer and asking them if they know what's going on. Maybe the act of removing the battery messed up the alarm's programming? |
#3 (permalink) |
the battery is after market but i installed it. the alarm is factory
__________________
#4 (permalink) | |
Quote:
This is probably a dealer installed non factory. Normally the trunk feature is programmable so I imagine the programming is messed up. And I have installed many, many alarms. David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow 93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ... 03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-( 99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten 96 SR5 Dune... 1.5kw stereo |
#5 (permalink) |
Sponsoring Member
My guess is that the alarm is in a failsafe mode 'cause it thinks that someone pulled the battery (or otherwise cut the power) to try to bypass it.
You're gonna need to figure out what the alarm is (mfg and model) then track down the programming instructions for it.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installing an Optima Red Top model 34/78 in a '99 Tacoma | p1michaud | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-03-2005 03:56 PM |
| Need help installing alarm | jayson161 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 01-06-2005 01:23 PM |
| Optima Red Top | WT | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-01-2004 06:24 PM |
| OPTIMA -- Red Top or Yellow Top | TRD 4RNR | 95.5-2004 Tacomas & 96-2002 4Runners | 43 | 06-29-2003 08:40 PM |
| Installing aftermarket alarm... | rpeAMP | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-01-2002 03:07 PM |
