'94 4Runner Rear Deck Window Problem
Hi,
New here so if this has been asked a million times please be kind.
Have a '94 4Runner V6. I was having trouble getting the rear deck window to go down for some time (not at all with the rear deck key switch and intermittently with the "inside" switch). I have replaced the guts of the window per a Tech. Service. Bltn. I found and now the window will not work at all. When I use either switch I can hear the relay click but no movement on the window. The rear wiper is in its proper position. I have pulled the "inside" switch and replaced it with one from a friend's 4Runner (same year) that I know works but no luck. Any suggestions?
Thanks
Thanks
voiddweller
19
05-02-2016 09:10 PM
cchinny
06-25-2015 08:11 PM
