General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1991 pickup no turn signals or flashers
Old 07-11-2009, 06:42 PM
YodaKrawler's Avatar
Okay so I have a 90 Toyota pickup and I don't have a y turn signals or flashers when I turn the flasher on the relay activates but no lights when I turn the turnsignals switch the relay makes no noise and I have checked the fuse
Now my thought was that even if there is no lights hooked up shouldn't the dash light come on and if you do have a light or two hooked up they should atleast illuminate. Any help would be great.
Thanks
Old 07-11-2009, 07:15 PM
jason191918's Avatar
To answer one of your questions, pretty sure at least one light has to work in order for the dash light to work, because they are in the same circuit.
Old 07-12-2009, 01:45 PM
Thanks for the rey will hook asmany lights up as I can find and go from there but I don't even get that with one light connected
Old 07-12-2009, 02:20 PM
Staff
DeathCougar's Avatar
The dash lights will work regardless of how many exterior lights you have hooked up. Have you checked wiring and fuses both under hood AND under dash?
Old 07-12-2009, 03:04 PM
yes I have the fuses that light when blown and I was wondering where is the relay for the turn signals I can't find them in the chilton book so then a thought would be the switches or I am not getting power to the switch
Old 07-13-2009, 06:18 PM
yeah thanks to all that responded but apperently the flasher relay has to work for it to flash went to a junk yard and pulled one out of a 1991 and put in my and walla it worked. the on that i found that i said was working was the silver one on the fuse panel and would click when i turned on the hazzards so i assumed that was the flasher relay and i was wrong so thanks again and i have turn signals. and flashers.
Old 02-07-2021, 03:04 AM
Shaggy Link's Avatar
turn signals and hazards
hey man so what did you do to fix them i am having a similar problem? mine specifically is no turn no hazard lights i know all my bulbs and fuses are good relay clicks for both hazard and turn signal switch selection but no lights
Old 02-07-2021, 10:40 AM
2ToyGuy's Avatar
You do realize the last post was 13 years ago?
Did you check the fuse for them?
If that's good and they still no worky, check the grounds behind the light unit. The whole thing will pull off, and the ground's behind it. They can get corroded pretty easy. Make sure they're clean, bare metal to clean, bare metal.
Worth a look. I'd check the fuse first, though.
Pat☺
milestone
09-29-2011 06:36 AM
silverstar4life
04-06-2011 09:17 AM
86blue4runner
12-26-2008 12:26 PM
Geographeen
07-11-2007 11:44 AM
not2shabby
02-20-2005 10:26 PM
Quick Reply: 1991 pickup no turn signals or flashers
