Spindle Lubricator For IFS Axle Shaft, '86 to '95 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-28-2007, 09:15 AM   #1 (permalink)
Tech Article Editor
Writeups@YotaTech's Avatar
Article By:
toyota_mdt_tech
OK, I was telling a few of you on the forum earlier about a spindle bushing lubricator.
I mentioned doing the needle bearings is a bad idea IMHO.
The bushings can squeal when low on grease, especially when its colder. Noisy spindles are a result of no lube.
Lubing is a bear and time consuming.
I have devised a tool for our dealership.
Did this about 10 years ago as a way to lubricate the spindle bushings without removing a little more then the hub (or ADD plate if ADD equipped) and pumping in grease with a grease gun.
Parts Required:
If you want to build your own spindle lubricator, you will need a few items. First, a piece of galvanized or steel water pipe.
A short threaded 2" piece exactly 3" long.
A spindle nut (the 54mm one) you know, the one so many use a chisel to set up?
For the life of me, how does one set preload properly chiseling a nut?
And you know who you are!
Step 1:
OK, now you will need a dead cap for one end of the pipe.
Either drill a hole and tap it for a grease fitting (most are 1/4") or a reducer end with another reducer till you get down to a grease fitting size (this is what I did).
Now braze the nut on one end of the pipe (opposite end of the blind cap) and braze it air tight.
No holes please.
Step 2:
Now remove your ADD plate or hub.
After the hub is off, remove one spindle nut, lock tab (the think you bend over to secure the spindle nuts with) the snap ring and thrust washer on the end of the axle.
Step 3:
Screw your spindle lubricator on the end of your spindle in place where the spindle nut you just removed was.
Now pump the lubricator with grease (manually fill the lubricator by had first to speed things up) and pump the gun till you see some grease show up coming out the other end, but only a smidge of grease.
Step 4:
Now remove the lubricator, and the spindle is full of grease so putting the axle back in will be tricky.
Here is what I do.
Install the bolt with washer into the end of the axle.
Just enough to get a screwdriver under the large washer.
Now pry under the washer using the hub stud as a fulcrum and draw the axle back into the bore.
Pull it till the extra grease smooshes out and set on the thrust and snap ring.
All done!
OK, now to keep your lubricator clean during storage (keep the grease from collecting dirt) set it in an old paint can cap.
Keeps your storage area from getting grease, and keeps the grease from getting dirty.
Any questions about this article, please contact toyota_mdt_tech, and not Writeups@YotaTech
Additional Note, Corey:
On the 54mm socket, most are designed for a 3/4" ratchet.
WabFab happens to carry one that had been modded to fit a standard 3/8" ratchet with no modifications required on your part.
Click here to see WabFab's spindle nut.
__________________
Greetings, this account may not be the author of this tech writeup, so please contact the author of the article for more information.
So please do not contact me, I am only putting the authors article here.
This account does not accept email or PMs.
Contact Corey for info.
Writeups@YotaTech is offline
Tags
12, accepts, bushing, bushings, fixing, galvanized, ifs, pickup, pipe, repair, shaft, spindle, threaded, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Spindle Lubricator® for IFS axle shaft. PICTURES! toyota_mdt_tech 86-95 Trucks & 4Runners 62 11-14-2009 01:35 PM
IFS Axle Shaft super boots kit, new, bay area toy4crawlin The Classifieds GraveYard 5 08-07-2006 09:15 PM
IFS axle shaft InternetRoadkill 86-95 Trucks & 4Runners 17 05-23-2006 06:54 PM
WTB:rear axle shaft off IFS truck (86-93) fishy1 The Classifieds GraveYard 4 02-11-2006 11:22 AM
2009 InternetBrands, Inc.
