Idler arm rebuild how to - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Maintenance & Repair
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-01-2008, 03:21 PM   #1 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Worn idler arms, very common thing. Most people will buy a new idler arm for 100 dollars plus! Here is how you rebuild it, to like new condition for under 10 bucks.
Symptoms:
shakey wheel on the hwy, sloppy steering.
To check:
Get a friend to get in your truck, and turn the wheel side to side. If your idler arm moves up or down its time to rebuild.
Supplies/tools:
-12mm socket
-19mm socket
-17mm socket
-14mm socket (if installing a brace)
-Long rachet for leverage
-17mm open end wrench
-14mm open end wrench (if installing a brace)
-Hammer
-Flathead screwdriver
-Grease
-Idler arm bushings
Removal No pictures due to greasy hands.
I found removal easier if your wheels were turned to full lock to the right.
-Remove 4 12mm skid plate bolts and remove and set aside skid plate
-Remove the idler arm cotter pin
-Remove castle nut
-Remove 3 17mm bolts holding the idler arm to the frame *keep track of the bolts, they are different lengths*
-Smack the relay rod with a hammer and idler arm should pop out"
*note*
Some have had problems removing the idler arm and have had to rebuild it while it is still installed.
Dissasembly
Using your flathead screwdriver pry off the idler arm cap. I had to tab the screwdriver with a hammer to break the seal.
Next remove the 19mm nut at the top of the idler arm. This holds the whole assembly together. It will probibly be very tight, I used a breaker bar for this job.
Remove the nut and remove the washer. Mine was pretty stuck so I had to pry it out with my flathead screwdriver.
Next, slide the arm out of the housing. If your idler arm has not been serviced in a long period of time, don't expect this to be easy. Mine was rusted in place and took a good whack or two with a hammer to get out.
Here is the arm out and the old worn bushings removed from the housing.
Your idler arm is now dissasembled.
Reassembly
Take your new idler arm bushings (pt# 90386-18002 for 86-91 trucks and 4runners) out of the packaging.
Here are the old vs. new bushings
Now, do not lube your bushings yet. Install them into the housing dry. They are a tight fit so carefully use a hammer to tap them into place.
Lube the surface of the bushings now.
Generously lube the shaft of the arm assembly and slide it back into the housing.
Slide on the big washer followed by that 19mm nut. Sinch the bolt down tight. Torque the big nut to 58 ft–lb.
Last but not least, tap the idler arm cap back into place. Feel free to use a little adhesive here to make sure it will not fall off.
If you are installing a brace or have one installed already. The big flat washer and the idler arm cap are not reused.
Re-install
-Slide the arm into the relay rod
-Install 17mm castle nut loosly
-Install 3 17mm bolts holding the idler arm housing to the frame *torque to 105ft-lb*
-Tighten 17mm castle nut on relay rod to 43ft-lb
-Install new cotter pin
*Optional stuff*
You can also drill, tap and add a zerk fitting on the housing so you can grease it regularly.
Brass bushings are also available for around 45 dollars. But you will probibly need to machine them to fit:
http://www.custommachiningusa.com/Specialty_Items.html
DONE
You should now have much better steering feel and smoother operation.
All for under 10 dollars and an hour of your time.
I would rate this job a 3 out of 10. If you can do your brakes, you can defantly rebuild your idler arm.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Tags
arm, brace, ideler, idler, ifs, kit, pickup, rebuild, relay, removal, rod, shakey, toyota, wheel, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Idler arm rebuild woes Matt16 86-95 Trucks & 4Runners 19 05-10-2009 11:11 AM
Idler Arm Rebuild? Saint_Berzerker 86-95 Trucks & 4Runners 5 09-20-2006 03:59 PM
Replace or rebuild idler arm? Tiger Paw Maintenance & Repair Archives 2 05-02-2005 10:16 AM
idler arm rebuild Churnd 95.5-2004 Tacomas & 96-2002 4Runners 2 01-16-2003 01:48 PM
Idler Arm Rebuild MNRUNNER Maintenance & Repair Archives 10 12-02-2002 01:31 PM
2009 InternetBrands, Inc.
