| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
its kind of a pain in the butt, you will have to rewire the drivers door lock motor thru the keyless brain. if its wired backwards, it will at the very least blow the fuse, if not, it will smoke the factory lock circuit.
although with your car, the wires should be in the drivers kick panel, so no need to run the wires into the door. you shouldnt need an extra relay, because the vehicles door locks are currently set up as a negative trigger, and for the unlock of the drivers door, you will be using the internal relay in the 712t. there are many an installer with 10+ years experience that cannot visualize the progressive locks, and how it works with a factory system, but if you have a very firm grasp on relays, how they work, and how to wire them, I can try and walk you thru it. |
#3 (permalink) |
Oh well... Thanks for your reply... the system worked great... basiccally... i had
RED 12v connected to WHITE (car) Last edited by Coolerpad; 07-24-2007 at 01:06 AM. |
#4 (permalink) |
Hey, is this same for a 2002 Camry? Am trying to hook one up but not sure how. I think I can identify the cars lock and unlock wires. Do you just need the "lock and unlock #30 outputs" (#5 & 8) connected to these? What does grounding the "Lock and unlock normally open #87" (#7,9) do? I just want basic lock and unlock funtions to work with remote.
#5 (permalink) |
Responed by Coolerpad
1- Red (+)12v constant power input connect to WHITE/RED location: (ignition haness) Last edited by Coolerpad; 07-24-2007 at 01:05 AM. |
#6 (permalink) |
Have a look at: http://www.the12volt.com/
#7 (permalink) |
Thanks Ken and 89dlx very much for the info! Will see if can get it to work.
#8 (permalink) |
Hi, I want to install DEI valet keyless entry 712t system on 1999 Toyota Corolla by myself. I got the wires information of my car and 712t, but I don't know how to connect which or where wires in my car. I often cut the wires and connect them in home. This is the first time in the car. you know, I don't want to damage my baby. so I ask help, who can give me some detail pictures how to do. Thank you.
| Tags |
| 712t, camry, dei, entry, frontier, hook, horn, install, installing, instructions, keyless, manual, model, system, valet |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| keyless entry | toyotaguy97 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-05-2009 03:26 PM |
| Valet Keyless Entry 712t | Coolerpad | Alarm Systems | 0 | 07-03-2007 01:11 PM |
| Keyless entry? | 97Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-10-2007 07:45 AM |
| keyless entry | aurunner | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-01-2007 06:30 PM |
| DEI avital remote start w/ keyless entry (same as viper) | profuse007 | The Classifieds GraveYard | 1 | 09-11-2006 07:59 PM |
