car alarm installation garbage - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Alarm Systems
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-02-2004, 06:28 PM   #1 (permalink)
Glenn's Avatar
Hi All
I was doing a some driving on a rough dirt road earlier today and the car alarm module fell out of the dash and I had to hold it with my left hand until I could get to a place to pull off and tie it onto the steering column temporarily. It has happened before and I am tired of taking it back to the installer place because they do not install it very securely.
I am wondering how hard it would be to install a new module myself with new alarm keyfobs. Is it something that is "plug and play" as in plugging in a new module into the existing wiring? Or are all modules different and have to be wired differently? I don't know much about where the wiring to the parking lamps goes or how it's wired to disable the starter. It doesn't have a lot of fancy stuff like keyless entry or remote start.
Any help would be appreciated.
__________________
-Glenn-
Glenn is offline
Old 03-02-2004, 08:02 PM   #2 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
It depends on what alarm it is. Some change harness styles some don't (when upgrading within the same brand).
I recently had my DEI 550 ESP sent in to be repaired and they sent me a new one with new fobs. I think the harnesses are the same, but I haven't gotten under there yet.
I need some nice weather, because I want to solder the wiring connections and re-route the wires and secure the module better. Mine also drops out of the dash like a soda machine...
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 03-03-2004, 06:51 AM   #3 (permalink)
Sponsoring Member
midiwall's Avatar
There have been a number of alarm/remote starter threads lately, you may want to do a search to see other folk's opinions and experiences.
Installing a system is pretty straight forward and is generally "easy" in the sense that you don't have to do any soldering (though I always recommend it).
Like Cebby said, unless you're swapping in a module from the same manufacturer you have now, there's little chance that it'll be plug & play. Even so, from what you say it sounds like you just have an alarm now and you'd have to add in the wiring for remote start and door locks (if you have them). Be prepared to spend some quality time on your back working in the tight space under the dash though - a lot of the wiring you'll need access to is on short leads off of the main harness.
I recently installed a system from Commando (http://www.commandocaralarms.com/ite...ProductID=1185). When I bought it, I got access to their vast library of wiring charts which I found to be 100% accurate.
In short... if you're comfortable with wiring (either soldering or crimp connectors) then there's really nothing to it.
Good luck!
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 03-03-2004, 01:42 PM   #4 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Cebby you should check out my thread where I located my 550 ESP just below the radio.
No problem with it ever falling out then!
Definately good to solder the connections if you can as well.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 03-03-2004, 01:56 PM   #5 (permalink)
Cebby's Avatar
Mines going somewhere else, but I'll never tell where. Let's just say, that it will make my rig impossible to steal. My old Celica a bit of an alarm in it. Here's a mock up shot:
This had 3/8" plexi over it screwed to the floor and custom carpet with a flap so I could show it off at security comps... Also had sheet metal with security fasteners under the dash and around this box to secure the wiring - kinda overkill. No time for that kind of monkey business anymore, plus, if I submerge the 4Runner using a floormount setup, I'd make a mess of it.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Tags
02, 4runner, 550, air, alarm, car, caralarminstallation, celica, cobra, dei, esp, horns, installation, manual, module, setup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
car alarm slammdrider Alarm Systems 9 08-23-2006 04:35 PM
Car Alarm Praufet 95.5-2004 Tacomas & 96-2002 4Runners 7 12-26-2004 10:22 PM
Alarm installation guides Hokiez97 95.5-2004 Tacomas & 96-2002 4Runners 2 01-24-2003 10:53 PM
Anyone have the RS3000 alarm installation manual? Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 8 09-17-2002 12:21 PM
2009 InternetBrands, Inc.
