| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#101 (permalink) | |||||
#102 (permalink) |
Front swaybar bushings worn out. I will fix'em as soon as I decide on factory or aftermarket urethane?
__________________
1998 Limited 4x4 stock 3.4L Window tint Midland CB w/Wilson 1000 antenna X-GM Truck Owner |
#103 (permalink) |
Front swaybar missing (took it off since it don't do squat to help on the trail or the road) Trip odometer (hit the reset button too hard once and broke it) body damage 87- Body damage transmission console cracked (bought it like that) tailgate latch for right side mechanism (need to go to boneyard and find one) but the tailgate is off anyhow-going to the net for my 94. dashboard illumination (the instrument panel works, but not the ventilation, or shifter indications)
__________________
DEPLOYED Again! 1994 SAS 2RZ/R151F=244:1! 1988 Toyota 4Runner SR5 |
#104 (permalink) |
[quote=4x4Lamm]Seeing all these rich kids at school with brand new cars is getting me depressed lately. I love my 4Runner but I also would love for it to work 100%.[quote]
Just place your front drivers side tire in the middle of a ricer hood . Any thing that may be wrong with your 4runner, just won't matter.
__________________
1991 4runner, 3.0 5 speed, locking hubs 33/12.50 BFG AT, 3in. b.l., airbox opened, modified exhaust no crossover pipe. ____________________________________ it's only too deep if you stop! www.opencarry.org |
#105 (permalink) | |
[quote=jimstoy][quote=4x4Lamm]Seeing all these rich kids at school with brand new cars is getting me depressed lately. I love my 4Runner but I also would love for it to work 100%.
Quote:
Lamm
__________________
-1992 4Runner SR5, Destroyed by fire. Lots of mods. I will miss it. -1995 4Runner SR5 Limited, Also known as the money pit. Becoming a trail rig now. -2004 Tacoma SR5 TRD, My new daily driver. I love this truck! |
#106 (permalink) |
Aarrgggh, what weekend! Okay, the short list is outer tie rod on Driver's side, sway bar bushings need replacent, sheared grease fitting (again) on driveshaft, a few other misc. things that need to be fixed.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#107 (permalink) |
Where to begin...
Holes rusted through the floorboards Holes rusted through the sides and bottom of the bed Clutch master cylinder leaks It is painted with Herculiner and it is flaking off badly The alternator light and brake light stay on whenever it is running Drivers side brake light won't work - yes I replaced the bulb Really crappy redneck exhaust Bad front end vibration with hubs locked Broken windshield - I mean really, really cracked all over, not a little chip Sliding rear window broken latch Shifter is broken, you can twist it all around Radiator mounts are broken Leaks oil Loose u-joint in the front No e-brake No sway bar - like I would leave it on anyways! Bad idler bearing pulley That is about all I can think of for now. Heck I only paid $300 for it. I have done a ton of work to it, two engine swaps and pulled the tranny once. It actually runs really good, a hell of a lot better then it did when I got it. I have almost no money invested in it. It is an 83 so solid front axle. It will wheel with the best of them, and no worries about hurting it! Actually a damn reliable beast. |
#108 (permalink) |
Not to brag... but almost *nothing* is wrong with mine. I go through upper and lower ball-joints enough to keep Toyota in the $$, and I need to get a new Pitman arm. Aside from that and the tranny I had put in, my 4x4 has been almost perfect. Awesome piece of machinery.
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console sometime: rear locker some sometime: retire the IFS My truck page Photography: http://www.aspen-graphics.com |
#109 (permalink) |
inner and outer fender on passenger side
control arms hood radiator support fan fan shroud battery cracked in half had a date with a phone pole.......they broke up
#110 (permalink) |
I have fixed a LOT of stuff on mine and the only things lefft are:
1. AC doesn't work 2. Check engine light is on.
__________________
--Miles Sold '91 4runner, 22re, 5 spd manual, 180,000 miles, cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods: My 4runner page My 2006 Camry page I'm a Myspace Addict! |
#111 (permalink) |
Here's the list off the top of my head....If I do some more looking I could probably find more. But with 227000 miles it's not doing too bad.
Replace the windshield (it's really pitted) Fix the Tranny (It's about to die) Replace the shocks Replace all the bushings (most of them are about dust) Passenger side valve cover leaks Battery is starting to have issues Rear diff is starting to leak Passenger side window switch doesn't roll the window down only up Need to add a brush guard, lights, hi lift jack, cb. |
#112 (permalink) |
Guest
My latest broken stuff or nearly broken.
spark plug wires are weak (repaired) K&N filter is dirty power steering lines are slightly leaking every now and then when taking off from a stop I hear a pop in the front end speedo cable needs to be lubed up |
#113 (permalink) |
I've got a couple things gone wrong with my '83 4x4. Well...
1. My defrost wont work on the left side. Once I flip on the defrost things will clear up accept for the left side of the windshield and my drivers window. I'm not sure why... 2. My drivers side floorboard is getting wet durring rain! I can actually feel the water dripping onto my feet right around where the gas pedal is. And I'm pretty sure its not due to a faulty windshield gasket... Other than that I can't think of anything right now. Can anyone give me some ideas to fix these problems? --Jonathan Last edited by lookin4x4yota; 01-12-2005 at 10:05 PM. |
#114 (permalink) |
A couple problesm with my Toyota
1. My defrost wont work on the left side. Once I flip on the defrost things will clear up accept for the left side of the windshield and my drivers window. I'm not sure why... 2. My drivers side floorboard is getting wet durring rain! I can actually feel the water dripping onto my feet right around where the gas pedal is. And I'm pretty sure its not due to a faulty windshield gasket... Other than that I can't think of anything right now. Can anyone give me some ideas to fix these problems? --Jonathan I'M NOT EXACTLY SURE WHY IT POSTED TWICE, SORRY ABOUT THAT. Last edited by lookin4x4yota; 01-12-2005 at 10:05 PM. |
#115 (permalink) |
No problems right now, occasional weird squeaks, though
__________________
Sean <>< 1995 4RUNNER 3.0 5SPEED FIPK, Borla, Stubb's Standard SKOs, 100W Hella 500's,PP Springs, 33x10.50 BFG AT, cute redhead http://community.webshots.com/user/racer944 http://s26.photobucket.com/albums/c119/racer944/ |
#116 (permalink) |
on the runner: ac blower is insanely loud but stealership needs to special order a new one to fix it, not worth it
on the taco: i havent physically seen my taco yet, its back home and im stuck here at school, so ill just say its perfect, heh
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#117 (permalink) |
broken passenger side cup holder...
__________________
-1998 4runner, Sonoran Steel #1 lift, 1" bl, 33x12.50 bfg a/t on black rims, custom dual exhaust with a vortex. -and a fast yz 125 -Daniel |
#118 (permalink) |
1 Leaking steering box
2 Leaking PS pump 3 Front DS CV about to grenade 4 Valve pans leak 5 Knock in bottom end 6 No fan shroud 7 Misfires sometimes 8 Speedo bounces 9 Shifter sloppy 10 Rear window doesn't work when its hot outside 11 No center vents 12 Some dents 13 Power rear window switches work 5% of the time 14 Tranny slips on takeoff, #1 Solenoid code 15 Inner tie rods bad |
#119 (permalink) |
1. Clutch is going out
2. Transfer Case leaks oil 3. 4x4 does not work as it should (not worth explaining, probably has to do with #2) 4. 15 mpg ![]() Thank goodness for extended waranty! |
#120 (permalink) |
1 Most clips broken on interior panels
2 Rear speakers do not fit in doors correctly 3 Driver's window makes weird noises 4 Right front fender squeks due to a crappy install by me after my accident 5 Mad scratches, dents and dings 5 Headliner is pretty beat, carpets are damn dirty, and interior forever smeels like Taco Bell
__________________
Jason '06 F250 Super Duty Daily Driver '01 Toyota 4Runner Sport 265/75/16 BFG ATs, OME 881s w/ spacers front, OME 891s rear, SS roll bar, and some other stuff. Out of Commision njttora.com |
#121 (permalink) |
New timing belt, tensioner,idler pulley,waterpump,all with 21,000 miles on it!Makes me wonder whats going to happem with 70,000 miles on it.Just to cheer me up.I go and look at all the recalls on ford,gmc and dodge and chevy.Why cant soemeone build one right the first time.Sometimes it feels like I bought a ford.Now the older toyotas 91 to 94 I think are having cracked steering linkage causing steering failure.That sounds good.But so dose the 05 gm trucks.They have a sub standard bolt on theirs that fails and have no steering either.Looks like a crap shoot no matter what you buy.
#122 (permalink) | |
i hope all those repairs have been made from 2004
drivers window rail, window still usable warped rotors
__________________
sarcasm noted...and appreciated im with the banned Quote:
#123 (permalink) |
1996 Limited 146k, i have replaced:
all front ball joints and control arm bushings, steering rack and endlinks, and the lift. Problems: drivers side rear seatbelt tensioner, both rear seatbacks rattle on occasion, clunk in the front end, and the stupid middle steering rack bolt is jammed in there and I have not been able to get it out and put a new one in. antenna fell into the fender, I need to permanently mount my Sirius radio tuner and antenna and mount my scanner and CB and antennas. I do what i can, balancing school full time, working 40hrs a week and trying to go to the lake as much as I can. then messing with the truck.
__________________
- Kyle Former Owner of - 1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06 OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2 |
#124 (permalink) |
210k on the odo. give it hell every day and nothing wrong at all. Replaced plugs and wires a while back, orig. motor, orig. transmission
#125 (permalink) |
-slight rust on the undercarraige
-grinding shifter due to cracked shifter seat (have parts) -imperfect paint (will not be fixed, only worsened) -girl I need to marry other than that, im good..
__________________
1998 Tacoma Standard Cab 4x4 -5 Speed -2.7L 3RZ-FE -80,000 Miles -custom ISR Mod -Purolator Fuel Filter -Royal Purple -Marlin Crawler Shift Stuff -Lots of Plans -No Money |
| Tags |
| 4runner, 91, axle, broken, celica, cv, differential, fill, front, plug, rear, rot, toyota, trac, transfercase, water |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A/C is broken | Shirleyda4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-14-2007 08:03 AM |
| What have you broken??? | apalmer1 | Off Topic Talk | 10 | 04-12-2007 09:44 PM |
| Exactly how can I tell if my cv is broken | wailukutoy | 86-95 Trucks & 4Runners | 8 | 04-11-2006 06:41 PM |
| just broken in | motoracer47 | Off Topic Talk | 1 | 09-12-2005 09:17 AM |
| HELP! broken? | Short1 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 01-24-2003 04:26 PM |
