weber 38...just for the record
i bought a truck a few years ago with a weber 38 and an inline elec pump. worked ok, made a little noise. the pump burned out and i replaced with a carter 4070 after reading through the yotatech forum archives. the carter was way loud, so loud that everyone always asked what was buzzing. it was very loud and i couldn't stand it anymore so i put the stock mechanical pump on and guess what... it runs just fine, better than ever, in fact... so if you are gonna run the weber 38, i want you to know that the stock pump works perfect for me. make sure to connect to your fuel return line and it should be aces.
A weber only wants to see 4-5 PSI of fuel pressure and most of the generic carbed electric pumps put out 8-10. So yes I bet it does run better. Especially if the stock pump on yours has a return line and it's hooked up.
