sagging Bilstein shock
Old 05-27-2009, 12:16 PM
buhrito's Avatar
'98 Tacoma Reg cab
2.7L, 5spd, 4wd
I have Bilstein shocks (10" 5150 Series with 255/70 valving). They came on the truck and I don't know much about them.
The rear left shock always sags a little. At best, about an inch and at worst, maybe 2-1/2 inches, or so.
Anyone know if these can be adjusted in some way?
thanks
Old 05-27-2009, 12:25 PM
4Crawler's Avatar
Shocks like that should have no affect on the ride height at rest, they only control the damping of up and down motion. If one corner is sagging, likely a problem with the spring or other suspension part on that corner. I think there was some sort of factory recall or TSB on the earlier Tacoma rear springs that you might check into.
Old 05-27-2009, 12:51 PM
buhrito's Avatar
ah yes, that makes sense. I added leaf springs to an S-10 I once had so, hopefully I'll be able to do this one too.
Any recommendations on what to order? I see some companies state that their springs provide "near factory ride height" or something along those lines. Since this Yota has 10" shocks, I'm not sure if that's what I would want.
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: sagging Bilstein shock
