Restoring wheels
Restoring wheels
When i bought a set of tires they came with a good set of wheels, only thing is the wheels' clearcoat is starting to spider and crack. How can i fix this? I was going to sand them down but i dont want to leave tons of scratches in my wheels. What do you guys suggest?
Cracking on the bottom part.
notice i said 800 and above, and when you wet sand theres less friction so there are less scratchs. try 2000 grit and wet sand it, then im sure that wont scratch them at all.
Yeah highlux is right. some decently "rough" polishing/buffing compound should get through the clear coat, then hit them with some aluminum polish if you want it to shine.
You can get some liquid buffin compound in bottles, i dont knkow how they rate the grit, so you will have to do a little research, but my guess is that you should get close to the roughest one you can.
Im no detailer so i can only tell about the materials i have used, but that liquid compound should do the trick.
This is the stuff i am thinking of.
http://www.ehow.com/how_2141516_buff...-compound.html
It should be pretty cheap for a small bottle. Let me know if it works!
But keep in mind i only THINK it will work, i dont know for sure
Oh and it will coat the wheels in black junk, it happens when polishing aluminum, a rag will wipe it off.
Hope it works out for ya!
Why didnt any of us think of this lol
http://www.google.com/#sclient=psy&h...36e88d83826287
Almost every link on the first page says to use some sort of paint stripper. You can decide what will work better.
