To Rebuild or Not? W56 Transmission
Somone gave me a used W56 transmission that they pulled from their 87 4Runner about 10 years ago. I have planned to swap this in place of my L43 in my 79 truck. It seems to shift fine and the shifter is not loose. Should I rebuild it before installing it or just put it in and hope for the best? I don't know how many miles are on it. The person that gave it to me said it was fine when he pulled it. He pulled it out when he put a Chevy small block in his 4Runner.
What would you guys do?
Thanks
brian
Thanks
brian
I would call Marlin Crawler and ask them about potential issues with the tranny and if it's worth rebuilding. My understanding is the W series transmissions aren't the strongest, but it may be a considerable improvement over the L43...they will also know if it will bolt right up or not.
thanks for the replies. I will probably just try it. I've known the guy for a few years, he wasn't trying to get rid of it. I was at his place getting some other parts and asked him about it, he said I could have it so i took it.
I'll keep you posted. I've got a big project this spring, full build up on my 79.
Gears, lockers, lift, high steer, 4.7's, onboard air. I have most the parts now but need a few more...
crammit442
7
11-29-2017 12:30 PM
Tigbucket
07-30-2015 07:29 PM
shadowbirdie
07-21-2015 10:38 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
07-19-2015 01:32 AM
2wd, 4wd, block, california, chevy, issues, kit, rebuild, rebuilders, rebuilding, small, swap, synchros, toyota, tranny, transmission, w56
