Misfire cylinder#2 has me stumped!!!
Old 01-31-2012, 01:01 PM
Basnbuks's Avatar
Hey guys i have a 97 tacoma 3.4 thats giving a #2 misfire code, ive changed the plugs and wires ohmed the coil pack swapped coilpacks around and still get this. Heres the kicker anything i do like pull the plug and replace it will run fine for a mile maybe 10 then comes back. Ive been told to do a valve leakdown test and to check the crank pulley bolt but if i had a issue there wouldnt it miss all the time?
Old 01-31-2012, 01:14 PM
Basnbuks's Avatar
Ive also checked the injectors for pulse
Old 01-31-2012, 01:50 PM
Team420's Avatar
compression test?? Always the best place to start....
Old 01-31-2012, 02:06 PM
BMcEL's Avatar
x2. ..
Old 01-31-2012, 02:10 PM
Basnbuks's Avatar
No i havnt yet will this weekend i just fig if it was mecanical it wouldnt ome an go
Old 02-05-2012, 07:30 AM
99SR5's Avatar
low compression would def cause a miss
Old 02-05-2012, 09:18 AM
Basnbuks's Avatar
Comp test was 200 on all cyld except #3 was 180. Pulled injectors and swapped #2 and misfire moved, gonna pull them again and send to witchhunter.
shooter86314
01-07-2016 07:05 AM
zanzabar0
10-11-2015 02:56 AM
dzldust
7
10-06-2015 05:39 AM
the_supernerd
10-01-2015 09:20 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Misfire cylinder#2 has me stumped!!!
