How to test fuel pressure regulator?
Old 10-08-2011, 09:51 AM
dave84's Avatar
Did you ever figure out your fuel pressure problem?
Old 10-17-2011, 05:26 AM
Squirrelmista's Avatar
Sorry, I have not had time to get on here lately... But no, I havent found my fuel pressure problem... Havent had the time to work on her in a few weeks! And really wont have the time for a few months to come, so I am just gonna put her in the shop. Tired of messing with it. Will let yall know what the mechanic says! Thanks for every ones input though!
Old 10-21-2011, 08:43 AM
Ok guys, so b4 I sent her to the shop, I found out why I had low fuel pressure & low voltage... The fuel pump wiring had a bad ground! So I just ran 2 new wires... Problem solved, but I still had an issue with the timing... Went to the shop yesterday! Will fill yall in when I get her back...
Old 11-13-2011, 09:55 PM
kemikn2010's Avatar
fuel problems on an 85 4runner
okay so I got my first toyota yesterday it drove around all day just fine when I went yo drive it again I realized that I had left the switch on for the fuel pump (its been wired to a switch) it was on for about 2 hours I now can get it to start to when I turn over the engine it does just fine when I turn over the engine with the switch turned on the check engine light comes on as soon as I turn off the switch the check engine light goes back off I have checked for spark its good and the4runner also wont fire using starting fluid any help or info would be great
jbv808
08-06-2021 04:47 PM
Doug4320
03-24-2018 10:11 PM
Poppie51
07-23-2015 05:03 PM
v_man
07-23-2015 04:01 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: How to test fuel pressure regulator?
