Hi-Lift Jack & Amsteel Blue Whinch Rope
I'm gonna try out an alternative to using a length of chain the following:
http://offroadrecovery.com/c=20mCct...d/product/58727
I sent those folks a question about it and got the following response:
On your 2" RATCHET STRAP WITH CHAIN ENDS 10,000lb product, it indicates that a pair of these could be used with a hi-lift for winching. Do you have any recommendations as to whether that would actually be effective, or is there too much stretch in the straps, or...?
The thing I worry about the chain ratchet strap is the rating. If 10k is the breaking strength, the working load limit is probably 2 or 3k. Although, a lot of people probably don't realize the wire cable sold with a 9000lb winch is only rated to ~2000lb. The breaking stregth of the cable is really just over 9000lb. This might not be such a huge deal with an electric winch, but with a hi-lift you're in basically the worst place possible if something breaks, so it pays to be extra careful.
As far as chain goes, what sizes have people used? I see warn sells a 5/16" grade 70 choker chain for use with a 12,000lb winch, yet the working limit of the chain is only 4,700lb. I was thinking of going 3/8" grade 70 with a WLL of 6,600lb, but it's more expensive. Anyone used the 5/16" chain much for winching?
BTW, I found the 5/16" x 20' tow chain sold on most offroad websites for $40 - $60 + S/H at Home Depot for $32.
http://www.tarpstop.com/CARGO/ratchets.htm
Pretty good prices on chains, too, but shipping is steep on something that heavy.
Also, I checked with the manufacturer of Amsteel Blue, and the minimum bending radius of the rope is 8x the diameter. I was hoping to get away with bending a rope around the 7/8" pin of a D-shackle, not to have the rope slide over the pin, but to half the length of the rope by doing a 180 around the pin and then pull on both ends of the rope from the same point. Guess I'll have to spring for the snatch block if I go this route in order to get the larger turn radius.
#26
A 4 ton come along from Harbor Frieght is around 20 bucks, I personally wouldn't feel safe using a hi lift for winching, it kinda worries me.
http://www.harborfreight.com/cpi/cta...Itemnumber=543
My guess is it fails at 8000lb, and probably not in a safe way. 1/4" 7x19 galvenized steel wire cable has a WLL of only 1400lb, while the high lift WLL is over 4000lb, with a safer failure at 7000lb (shear pin fails, jack supposedly stays put). I'd personally hate to be standing over a wire cable if it broke.
Also, I know you usually get what you pay for, and $30 doesn't pay for much.
Again, not knocking the idea. Just more thoughts on the matter for others who may be researching recovery ideas. I'm sure that there are plenty of people using the come-along who will now put me in my place.
#27
Originally Posted by captainamerica
I'm definitely not knocking your idea, but I've thought about that option, too. I'm guessing you're referring to this:
However that was before I had a truck that was locked front and rear.
ashamsuddin
17
01-13-2023 03:17 AM
nvwiggins
13
06-16-2016 03:05 PM
charlie_fong
09-27-2015 10:06 PM
